Author Topic: My little Demon so far.  (Read 61640 times)
Offline Doc
    • My Youtube Channel
Re: My little Demon so far.
« Reply #225 on: March 27, 2017, 06:10:15 PM »
Thanks guys!
I just had to start it yesterday just to see haha.
Ps I did find another error I with coolant system the back plate with the slot cut that is suppose to join the left and right side was wrong.
So more than likely that is why the pump is forcing it out past the seal. There isn't anyplace for it to pump the coolant.
« Reply #226 on: March 27, 2017, 11:04:51 PM »
That would do it! It's good to see them both running!
Offline Doc
« Reply #227 on: April 03, 2017, 01:12:14 PM »
Guess who made the front page of the local paper.  :coffee: I actually got talked into it after a friend suggested the paper do a write up.
Jamestown Sun
« Reply #228 on: April 03, 2017, 04:48:00 PM »
Way to go Doc! It's nice to get some recognition on a job well done thanks for taking us along!
Offline Doc
« Reply #229 on: June 25, 2017, 10:00:28 PM »
Thanks Tom!
I haven't checked in in awhile. Been busy with garden stuff but did get a little shop time the last couple weeks here and there. I did get motor box's or stands done and did model up a radiator that I'm gong to attempt to build. Going to use aluminum for the fins not sure if my plan will work or not but I'm going to give it a try anyway. The reason I'm going to try and use aluminum rather than brass it will conduct heat almost twice what brass will. And I just want to see if this will work. ;)  Anyway here is a video showing the box stands I made.
