Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to MadModder!
Home
Help
Search
Login
Register
Gallery, Projects and General
The Design Shop
Making tools to make tools: Yoke style radius cutter.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Making tools to make tools: Yoke style radius cutter. (Read 8882 times)
NeoTech
Hero Member
Country:
on:
August 08, 2013, 04:08:59 PM »
So i need to cut som rollers to be able to bend som tubing to be able to make the frame for my bandsaw project.. Oh well enough. ..
I wanna make a yoke styled radius cutter mainly cause i find them more versatile then the "dreamcutter" and the other weird ball cutter..
But i wonder if the yoke frame would be made out of aluminium.. And if not, could i cast a frame with embedded steelrods for support (i would heat bend som rod and put in the mold).
Or do i have to go the 20mm plate route and grind the shapes. *tedious*
Logged
Machinery: Optimum D320x920, Optimum BF20L, Aciera F3. -- I have not failed. I've just found 10,000 ways that won't work.
http://www.roughedge.se/blogg/
BillTodd
Hero Member
Country:
Colchester Essex (where the lathes were made)
Re: Making tools to make tools: Yoke style radius cutter.
Reply #1 on:
August 08, 2013, 05:05:11 PM »
Aluminium would probably work fine. There is not too much stress on the cutter while taking light cuts (typical of radius cutting)
FWIW I machined rollers for my brothers pipe bender using this fairly simple rig:
Last Edit: August 08, 2013, 06:27:01 PM by dsquire
Logged
NeoTech
Hero Member
Country:
Reply #2 on:
August 08, 2013, 05:22:03 PM »
I see.. that looks .. sketchy but if it works it works!. =)
I thought i would make something that hold the cutting road in a bow, and then had a handle to turn the toolbit. But well then i make it out of aluminium and press brass bushings in it.. Sweet. =)
thanks.
Logged
m_kilde
Jr. Member
Reply #3 on:
August 13, 2013, 07:01:51 AM »
BillTodd
That looks as a simple and fast way to produce internal round shape, thanks for sharing this video, will keep this in mind for future work.
Logged
Regards
Mogens
http://m_kilde.skysite.dk/
NeoTech
Hero Member
Country:
Reply #4 on:
October 19, 2013, 04:46:16 PM »
Been noodling with making my radius turner.. Im going with the yoke style.. I hade a piece of 20mm S355J2 plate lying around so i thought it was a good start.. and a piece of coldrawn tubing..
So for so good
Note, this is the progress for like 2 months while doing other stuff as well.. Idea is to put somekind of thrust bearing in the bottom and the top and use somekind of thread/bolt to get it to fix in the lower poistion and let it float in the upper... I dont know really i make as i go along..
Logged
mattinker
Hero Member
Country:
Reply #5 on:
October 19, 2013, 06:15:20 PM »
NeoTech,
I like the road your going down, it sounds very familiar, I make things to make things. I'll be following you!
Logged
Meldonmech
Hero Member
Reply #6 on:
November 25, 2013, 02:12:58 PM »
I find designing and making my own tools and workshop equipment most rewarding.
Logged
Print
Pages: [
1
Go Up
« previous
next »
The Design Shop
