Gallery, Projects and General => Gallery => Topic started by: BiggerHammer on January 20, 2013, 07:36:08 PM
Title: A simple tool for a simple problem.
Post by: BiggerHammer on January 20, 2013, 07:36:08 PM
I am kind of proud of this one. I thought of it on my own. However I am also aware that there isn't really much "new under the Sun".
Some of the guys where I am currently doing some work frequently have to "pull square" or "cross measure for square" on some large metal frames. Here is what I came up with to help them out.
(http://imageshack.us/a/img703/8652/thingbits.jpg) (http://imageshack.us/photo/my-images/703/thingbits.jpg/)
Uploaded with ImageShack.us (http://imageshack.us)
Purchased the magnetic squaring tool and the tape measure. Fabricated the aluminum bits from some bar stock and flat-bar. After assembling this is what you get.
(http://imageshack.us/a/img685/3504/thingr.jpg) (http://imageshack.us/photo/my-images/685/thingr.jpg/)
Now one man should be able to  stick the magnet in the corner, pull a diagonal measurement and repeat with the other corner allowing him to square up the assembly. This does not give a "true distance" measurement but it should give a consistent measurement between the corners which is all that is required to cross measure for square.
Title: Re: A simple tool for a simple problem.
Post by: roygpa on January 20, 2013, 08:11:51 PM
good idea!
Roy
Post by: Stilldrillin on January 23, 2013, 05:57:22 AM
Good, simple solution. To a, sometimes, frustrating problem......  :clap:
Post by: rdhem2 on February 14, 2013, 12:19:21 PM
Nice fix to an everyday, everywhere problem.  I will copy as any good idea always is.  One fix needed-----a "clip" of sorts to free the tape without tools or leaving the center plug attached to the tape.  Could be as close to perfect as possible after that!           :beer:
