Home Base => Announcements & Issues => Topic started by: BillTodd on January 03, 2013, 05:55:43 PM
Title: Animated gifs not working
Post by: BillTodd on January 03, 2013, 05:55:43 PM
Just noticed my animated gif images no longer work - have the setting been changed?
Title: Re: Animated gifs not working
Post by: Brass_Machine on January 03, 2013, 06:26:12 PM
Hi Bill
Nothing has changed server side. Can you post a link that has your animated gifs in it? How about the smilies? Do those work for you?
Post by: BillTodd on January 06, 2013, 09:43:07 PM
hi eric,
i've posted a couple recently ;
madmodder.net/index.php/topic,8025.0.html
madmodder.net/index.php/topic,7977.0.html
they both seem to have been converted to static gifs
Post by: tumutbound on January 08, 2013, 05:08:18 AM
Bill,
The first example you give is static but the second one is animated.
Post by: BillTodd on January 08, 2013, 07:59:33 AM
Sorry,  put that down to failing memory. :doh:
Both are animated: the first was converted to static when embedded
the second I initially tried to embed it but since that failed I later linked it.
So, linking works OK, but the 'light-box', or whatever you call it,  in which the graphic is displayed is converting the animated gif to a static gif (with no reduction in size of the file)
