Gallery, Projects and General => Project Logs => Topic started by: Bezalel on April 02, 2011, 02:56:45 AM
Title: 3MT Mill collet chuck
Post by: Bezalel on April 02, 2011, 02:56:45 AM
This is more of a record of my machine shop learning experiences.    ::)
Hopefully other beginners like me can learn from my unintended outcomes and the old timers well they might just get giggle.
                                                              :lol:
  For my first turning project I went ahead and made my first tool. which was a fly-cutter to bolt to the face plate. On an 8 inch face plate it covered a large surface. Machining up my second project (which was a much needed angle bracket)   I count both these projects a success as well as being very educational.
(http://i1095.photobucket.com/albums/i461/Bezalel2000/Early%20projects%20madmodders/P1010016.jpg)
Having bought a lathe without the benefit of 20/20 hind sight I soon discovered it is difficult to mill anything on a lathe that has no T slots in the cross slide. (you'll see in later photos).  :doh:
I don't think Mrs was quite as easily convinced  :poke: but it was obvious to others, This Workshop Needs a Mill.
Of course the type of mill drill I could afford, typically comes with a drill chuck but no collet chuck
So the start of my next Project #3MT Collet Chuck
Now on with some milling!  What .. No T Nuts!  :scratch:
Oh well! lets make some .. on the mill?
At this point there is a song stuck in my head.
###  With what shall I hold it dear Eliza? with what? ###   :palm:
by chance I have a few ½ Whitworth cap head bolts, (what a shame there not 5/8 I think they would fit even better) any way, if I file a few mm off each side of the head they should do nicely to hold the vice down while I mill a piece of bar to make some T Nuts (with light cuts of course, I don't want to rip a chip out of my nice new mill table)
(http://i1095.photobucket.com/albums/i461/Bezalel2000/Early%20projects%20madmodders/P1010022.jpg)
Now where were we – thats right making a #3MT Mill Collet Chuck.
The first hurdle is the #3 taper.
The book says the Taper starts at a diameter of .778 and for 3-3/8ths of an inch it tapers out 0.0502 per inch on the diameter.   :smart:
I don't know about you but as a novice I'm struggling to understand what it means let alone measure it with a ruler and calipers.  :zap:
But I have seen something that could help, on the cover of one of Tubal Cain's books. See below if Nexus Don't mind the plug
(http://www.boomerangbooks.com.au/bookImages/MEDIUM/504/9781854861504.jpg)
so from this example, if I mount the 3MT centre between centres ( at the head end center drill a piece of very old round bar) and then line up the side of the compound slide with the edge of the taper, it has to cut a 3MT right?
(http://i1095.photobucket.com/albums/i461/Bezalel2000/Early%20projects%20madmodders/P1010017.jpg)
Worked out  o.k. in my head but when I went to the lathe there's two problems    :doh:
1.the edge of the compound slide is well below the center height and
2.tail stock is in the way.
If I make a parallel block (on the mill) I can sit that on the compound slide and measure the gap at both ends of the center at centre height.
(http://i1095.photobucket.com/albums/i461/Bezalel2000/Early%20projects%20madmodders/P1010019.jpg)
The rest is is just threading and turning.
(http://i1095.photobucket.com/albums/i461/Bezalel2000/Early%20projects%20madmodders/P1010021.jpg)
(http://i1095.photobucket.com/albums/i461/Bezalel2000/Early%20projects%20madmodders/P1010020.jpg)
 :coffee:
Except the collet tightening handle and the bluing,  I'll talk about them another time.
Title: Re: 3MT Mill collet chuck
Post by: Rob.Wilson on April 02, 2011, 03:51:55 AM
Nice going bezalel   :thumbup:
Nothing better than making ones own tooling  :med:   ,,,,,,,,,,, i like your tapper setting block ,, good idea  :headbang:  :clap: :clap: :clap:
Post by: Bernd on April 02, 2011, 08:42:14 AM
Ya, I kind of know how that goes. Very interesting and amusing story.  :thumbup:
