Gallery, Projects and General => Project Logs => Topic started by: wquiles on May 17, 2011, 07:08:56 PM
My prior posts were about machining flashlights, so today I have something different. Instead of buying a replacement shift knob for my car, I decided to try make one on my own.
I actually started by creating a way to hold the Aluminum I would use for the shift knob, so I created a short shift rod. I started by measuring the original one:
(http://m3coupe.com/Honda/ShiftKnob/DSCF4979.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF4981.JPG)
Here I am making the copy. I am using 12L14 "leaded" steel:
(http://m3coupe.com/Honda/ShiftKnob/DSCF4976.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF4978.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF4983.JPG)
Once I got the shape right, I started threading (10-1.5mm):
(http://m3coupe.com/Honda/ShiftKnob/DSCF4985.JPG)
Checked the pitch against the tap after the first pass just to make sure!:
(http://m3coupe.com/Honda/ShiftKnob/DSCF4986.JPG)
And after a "few" pases I had a good fit:
(http://m3coupe.com/Honda/ShiftKnob/DSCF4987.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF4988.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF4991.JPG)
This material threads great!. Close-up:
(http://m3coupe.com/Tools3/DSCF4992_c.JPG)
My threading tools all use sharp carbide inserts. This one in particular is a Kennametal tool:
(http://m3coupe.com/Tools3/DSCF5022.JPG)
(http://m3coupe.com/Tools3/DSCF5023.JPG)
(http://m3coupe.com/Tools3/DSCF5024.JPG)
(http://m3coupe.com/Tools3/DSCF5028.JPG)
(http://m3coupe.com/Tools3/DSCF5025_c.JPG)
(http://m3coupe.com/Tools3/DSCF5027_c.JPG)
OK, enough of the tool porn ...
Once I cut the screw to length, it looks like this:
(http://m3coupe.com/Honda/ShiftKnob/DSCF4994.JPG)
And after Brownells "blackening" solution:
(http://m3coupe.com/Honda/ShiftKnob/DSCF4997.JPG)
I then started with a round piece of 6160 Al, about 2" in dia, and about 4" long:
(http://m3coupe.com/Honda/ShiftKnob/DSCF5002.JPG)
After the piece was faced, I drill and tapped it:
(http://m3coupe.com/Honda/ShiftKnob/DSCF5003.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5004.JPG)
I then started to give it shape (I supported from tailstock end most of the time):
(http://m3coupe.com/Honda/ShiftKnob/DSCF5010.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5011.JPG)
Once the shape was roughed out, I then started to do very light cuts using the compound:
(http://m3coupe.com/Honda/ShiftKnob/DSCF5076.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5077.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5078.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5079.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5080.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5081.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5082.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5083.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5085.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5089.JPG)
And then it was done:
(http://m3coupe.com/Honda/ShiftKnob/DSCF5090.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5092.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5093.JPG)
Before:
(http://m3coupe.com/Honda/CivicSi/DSCF4784.JPG)
After:
(http://m3coupe.com/Honda/ShiftKnob/DSCF5094.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5095.JPG)
(http://m3coupe.com/Honda/ShiftKnob/DSCF5096.JPG)
Will
Will,
A very good post, very informative. :clap:
I thought your photography was excellent :clap: :clap: :clap:
The gear knob was very well made :thumbup:
Very nice journey! Great pictures too... the end result looks very nice. What kind of car?
Thank you guys. It is a 2011 Honda Civic Si, 4-door.
Nicely shown making of the gearknob. And boy do you have a lot of fancy lathe tooling :drool:
I thought that steering wheel looked Honda-ish. (I have a Honda Jazz(Fit) - thinking about adding something like this)
Nice work, thanks for showing :clap: :clap: :thumbup:
I want that 6 jaw chuck, been after one for 7 months.
Just one small problem, the gear sticks on the wrong side.
Nice job Will. :thumbup:
One question though, how do you now know were the the gears are without it being lettered? :lol: :lol: :lol: :lol:
At least the Bison I have is definitely worth the wait. I got lucky that I bought it new on special, right before the price went up like 30-40%.
With mine I can mount work, do work, unmount, do something else, remount work and be off less than 0.001", and if I mark the piece before I remove and line up again with the same jaw, I am basically spot-on as before. At least for the projects that I do, I don't ever worry about the work being centered - the chuck is that good for the work I do (i.e., accurate enough for me).
Ahh - that is easy. I first drove the car for like two months with the factory shift knob, just so that I can memorize the pattern :)
In fact, I kind it find the whole pattern on top a "nice to have", but who really looks at it while shifting? :bugeye:
Will
Nice job and great pictures :bow:
Looks more interesting than my ball one I made for my car
(http://i602.photobucket.com/albums/tt102/ja2onx/knob.jpg)
How can it be on the wrong side? It's in the middle. :lol:
Looks good, I'm planning to make one like J45on's for my MX-5.
Ooh! this looks so nice.
I have a large Asian lathe with small levers that are probably quite adequate for smaller hands. You have inspired me to make some larger levers. Thanks.
-Dick
Very nice job. Not long ago I made an aluminum steering wheel knob for my tractor. It works like a champ but the aluminum does coat my hand after a few minutes so I've taken to wearing gloves. Did you put some sort of coating on the knob? May be beneficial if you didn't.
Looks nice, but try remaking it out of steel. You'll be amazed at how it seems to shift more smoothly. The weight gives it better feel.
VERY nice ;)
I need to try making a few more in Al to practice more, but yet, I "have" to do one in steel - I also read that they added weight is noticeable ;)
Will
Very nice, I was trying to work out what car it was. I should have realised, am thinking about a Civic Type S diesel for my next car!
Should be very noticeable 2.74 Specific gravity for Ally and Stainless about 7.8 Specific gravity!
