Gallery, Projects and General => Project Logs => Topic started by: Darren on December 03, 2009, 07:36:30 PM
Well enough bodging and showing bits of welded up scrap, time to do some precision work :thumbup:
I have an index milling cutter but no arbor, can't find it on the manufactures web site either. So I thought I'd make one after seeing Bogs today it reminded me :thumbup:
http://i202.photobucket.com/albums/aa102/bogstandard_photos/Swingup08.jpg
I mentioned some bar stock I recently sourced elsewhere http://madmodder.net/index.php?topic=2328.0.
This turned out to be no ordinary steel, it was pretty tough stuff. Can't cut it with the mechanical hacksaw or the bandsaw. Can't drill it with HSS either, though Cobalt drills were ok.
Because I couldn't saw it I had to part it on the lathe instead
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3849.jpg)
Cept my parting tool couldn't go deep enough :doh:
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3850.jpg)
Where there's a will ..... :)
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3851.jpg)
Now I had a shorter piece I needed to turn one end to 20mm, largest that will fit in an ER32 collet on the mill.
Oops, it got a bit hot ... :ddb:
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3852.jpg)
There, that's better
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3854.jpg)
Turned around and fashioned a bit. I need a 16mm x 1.5 thread to fit the tool ..(the flash makes it look rough, it wasn't really)
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3855.jpg)
Changed the change wheels on the lathe and here we are, a thread, better still it's the right size too .... :)
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3857.jpg)
And here's the tool.
Now I don't want the centre of the tool to butt up to the arbor, rather I want the outer 50mm diameter to take the load and stresses. It'll be more stable that way.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3861.jpg)
A little bit later and it's well on its way
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3865.jpg)
This spacer needs to be true and parallel on both faces, this is important or the cutter will wobble.
Meaning all drilling, boring and facing of both sides needed to be done without removing it from the chuck.
Here you can see I have done most of the work and almost parted it off, but not quite. I needed to face it first and at the same time finish parting.
Notice I have left side clearance to allow the swarf to escape during my final facing/parting .... :smart:
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3867.jpg)
And here we are, this is the parted face
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3869.jpg)
I wanted these parts to lock together as much as possible for rigidity. Notice the boss on the tool and the arbor fit into the spacer.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3871.jpg)
The final result, the spacer was pressed onto the tool on the press and the arbor is a very close fit. Because of the thread everything will only ever tighten up in use.
In fact if it ever needs removing it'll probably have to be machined off !!
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3873.jpg)
I think my new lathe works :ddb: :ddb: :ddb:
Darren
Very impressive. I can just about imagine the big smile on your face as you are making this. It's nice to have a machine that you can get serious with and get results without always having to back off. :ddb: :ddb:
Cheers :beer:
Darren, that's a fascinating looking cutter. In use, is it like a giant end-mill? Can you share where you got it from, or was it a lucky one-off find?
I'm loving your arbor too. Looking at pic 5, the one below the overheated bit, it looks like a really glassy smooth finish. In reality, is it that smooth? I'm finding I just can't cut a piece to be completely "baby's bum" smooth; there's always a very faint pattern on it & if I run my thumbnail along the length, you can feel a certain roughness. Not sure if it's me, or if I'm chasing a finish that's impossible. I'm currently using carbide tooling on mystery metal, FWIW.
:thumbup:
Well that was a good job well done Darren, :clap: :clap: :clap: :clap:
A good try out for your new lathe that ended up with a real beast of a cutter for your mill:- great stuff :thumbup:
Have fun
Very nicely done Darren.
I would think that cutter could be classed as a mover, it just moves metal out of the way.
Looks a bit pricey to retip though.
Thanks guys,
I though it would be a worthy exercise for us to get to know each other a little (not you, the lathe :doh:)
Bogs, yeah, frightening init ..... :coffee:
Adev,
It's really hard to advise without being there.
You will have a lot of variables, the material itself, tooling (size/shape/condition) condition of the actual lathe (bearings/leadscrew/ways/chuck/slides) and more, that's just the basics.
All the finishes you see in this post are from the lathe and cutter, no emery finishing or polishing was done except for burrs on corners. But you have to remember this is mostly down to the steel properties.
I find the harder a steel is the better it finishes. Same goes for alloy.
The threading was done with a HSS cutter as I don't have a carbide type yet, this was not the best choice here but it's ok, better than the picture portrays.
I used a worn tip shown in the rougher areas for bulk removal and a new tip were you see it shiny ... :dremel:
Your issues may just be down to the material itself?
I picked the milling cutter up along the way somewhere, the seller threw it in with a bunch of HSS cutters as he didn't have an arbour for it ....
Thought I'd better try it out now that I've made it :ddb:
This is a piece of cast steel from a steam engine basket .... don't ask ....
One evening a couple of weeks ago I had a go at it on the mill with a HSS cutter. Although it was tough it cut ok, but the cutters didn't last long before the edge was gone.
It was taking me hours to try to square this lump up.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3875.jpg)
So tonight I attacked it with the tipped cutter. This flew through it once I'd found the settings.
Tried 600rpm, no good, lots of vibration.
1000 rpm much better
1400 and it was now ploughing through this cast like butter.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3876.jpg)
Flipped it over and took a full 50mm face cut in one pass at 0.100", I think this is about the limit here, 0.050" sounded much better. This is cast steel though so ordinary steel should be much better.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3878.jpg)
It's not a brilliant finish, only the shaper can do better in my workshop with this material. But as a bulk remover this is the man that can, as Bogs says .... :lol:
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/IMG_3879.jpg)
Be interesting to see what it does to ordinary steel ...
BTW, this is very fast , really fast .... and the lump stays cold unlike when using HSS which gets it steaming.
Not good when machining this stuff as it can work harden in an instant. Then it's really tough to do anything with.
Very very nice! both the work, tooling and lathe!
Thanks for all the kind comments guys ....
Even though it turned out well enough I wasn't entirely happy with the end result.
This being how far the cutter was extended from the arbor and machine bearings. A lot of leverage there to induce vibrations. In truth it seemed to work well enough, but it was bugging me all the same ....
Here we have an ER32 arbour/collet holding the milling cutter arbour. The facing edge of the cutter is about 8" from the spindle.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3900.jpg)
So what I had in mind was a dedicated ISO30 arbor that the cutter fitted to directly ...
Except of course no such thing exists .... :bang:
So I'll have to make my own then ..... :dremel:
At first I thought of setting the compound slide over and cut the taper that way. I'd done this before for a short MT2 arbor.
But then this lathe has a taper turning attachment ..... Ooooh, new territory for me .....
In for a penny ......
First job was to study the taper unit and clean it as it was covered in thick oily gunge. Thankfully this has protected it well over the years and it seemed to be in fine condition.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3888.jpg)
This little fitting is taken off the end of the crosslide screw to disconnect it...
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3896.jpg)
And used here to connect the crosslide to the taper unit
Now the taper angle needed setting. This is 1" per foot or 16.7112 degrees. Thankfully the taper unit scale has both sets of markings and 1" sure is easier than the other.
Once set I used another arbor and a dial gauge to check and tweak slightly.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3886.jpg)
Having now lost the crosslide adjustments the compound needs to be set over to 90 deg for feeding in.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3889.jpg)
Having satisfied myself with the workings and how too's the machine was re-set back to normal. Except of course for the taper unit angle, that was left alone
A chunk of that tough steel should be perfect for this application ... :ddb: So a section was cut with the fiber cut-off saw. (not wishing to repeat the hacksaw teeth removing exercise)
Mounted in the 3 jaw and one end machined down to 17mm, This will later be turned to 16mm and threaded for the cutter.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3890.jpg)
Now it can be turned around and mounted in a collet. This end was turned to 31.4mm which is the thick end of the taper.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3892.jpg)
End section for the internal thread.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3894.jpg)
And now for the taper, the machine was re-set and ...........................................................oooooh the nerves .....
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3898.jpg)
Went without a hitch, not a murmur ..... bit of an anticlimax really ....
Turned around to cut the thread, 16x1.5mm
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3899.jpg)
Here's the thread, not as bad as the picture would have you believe, looks rough but it's not.
At this diameter this steel like to be spun fast to cut properly. 1200rpm is way too slow, my next speed is 2500rpm at which I get a chrome like finish.
But there is no way I'm gonna do any threading at 2500rpm, not on your Nelley ... so this will have to do ....
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3901.jpg)
And the cutter fitted
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3902.jpg)
Looks good dunit :) :) :)
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3903.jpg)
Here it is compared to the ER32 holder with a cutter in it. As you can see my new arbour is shorter .... :)
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3904.jpg)
Now the moment of truth.
All the time I was turning the taper I had nothing I could test the angle with as it was being made and adjust as needed .... Fingers crossed ..... :med:
I marked the surface with several marker pen lines and fitted it to the milling spindle. Just in, quick turn and out ...
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3906.jpg)
Oh was I chuffed, my heart could start beating again ..... you couldn't ask for better than that :)
Now it looks very reasonable
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3908.jpg)
A close-up
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3909.jpg)
I'm over the moon with the result, truly I am .................. :mmr:
Isn't it nice when things go right?
Certainly is John..... and without people like yourself to guide me along with all your little tips and projects, I'm sure the result may have been quite different :zap:
Darren
Another great piece of tooling. It not only gives you a more stable tool but I am sure that you will find times that the extra headroom will be of use which will make it even more versatile. Good writeup too. Thanks :ddb: :ddb:
Cheers :beer:
nice job darren........it is a great feeling when you make a new piece of tooling for the shop!!!!
chuck :wave:
Cracking job Darren that lathe certainly got some good features :headbang: :headbang: :headbang: :headbang: :clap: :clap: :clap: :clap: :clap:
Have fun
Hi Darren
:bow: :bow: :bow: :bow: :bow: great job , i hope my TTA works as well as yours
Regards Rob
Darren while you're set up why not make a few more of those holders spare you can leave the the fixing end blank until the job comes along for them.
Have fun
Darren, superb work there, itlooks really good. :bow:
Thanks Guys,
Now I know I can do this it should open a few doors.
Stew, I'll leave the taper unit setting as is and run off a couple or three as I have some tooling that could be utilised if only I had arbors for them.
Rob, judging by the standard of your work I'd be surprised if your TTA wasn't a dream to use. Having now used one I can see what the fuss is about.
The first attempt won't be wasted, I was eyeing it up tonight for another job with a slight adaption .... :dremel:
Did you try it with the side "flutes"? With the inserts staggered like that it almost looks like a roughing mill. I'm wondering what kind of finish it would leave.
Nice work all around. :beer:
According to the Sandvik web site this is a rapid rate metal mover ie a roughing cutter ...
Having used it the removal rate certainly seems fast. I've only tried it with cast steel so far which it coped well with. The side flutes do work well but did not leave a "finish" that we would normally accept.
Its main asset will be for general shaping and initial sizing of a larger block to something that can then be finished with another cutter.
Sandvik do make finishing cutters, just not this one. The tips leading and exit angles are wrong for that purpose from what I can gather.
I just scored 30 new tips at £24, so expect to see more of this beast with all the scrap I seem to be starting off with !!
I needed to make some little square blocks to fit keyways on my milling spindle. The ones that stop the arbor spinning and ruining the spindle taper.
So with the new "proper" and shorter arbor I made these blocks from some cast steel.
As you can see the finish is now much finer, a normal HSS milling cutter wouldn't do better with cast steel.
So my reservations about the length of my first arbor were correct, it was indeed too long and causing some problems.
The longest edge on these blocks is 18mm to give an idea of scale. Compared to the finish on the cast iron vice I did some time ago there is little difference in the finish.
The blocks would clean up quite easily.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/IMG_3915.jpg)
I decided to modify the original arbour I made to take some slitting saws that I have.
For some reason I decided to test the run out when I fitted this back onto the lathe in the 5C collet. With my dial indicator I couldn't see any movement, I checked, fiddled and checked again. Nothing :scratch:
It couldn't be nothing as I didn't even index the part to the collet. So I changed indicators from 0.001" res to one with 0.0001 res.
Now it moved, by a whopping 0.0002". Ha, pure luck I'd put the part back in the collet at exactly the same position I thought.
So I turned the part in the collet out of pure interest and measured again .... barely 0.0001 ... I give up ..... :med:
Anyway, the boss was turned to a very tight 1" to match the slitting saw.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/Slitting%20Saw/IMG_3922.jpg)
And the other cutter I have with a 1" bore ..
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/Slitting%20Saw/IMG_3923.jpg)
Next I need to chop the end off, face, drill and tap 10mm for an end cap.
But before I do I thought I'd throw this out to some suggestions.
I have 5 identical slitting saw blades, they are 3" dia carbide x 0.0245" thick. I seem to remember Bogs getting some spacers and fitting several saw blades at a time to make an engine cooling fin cutter. Can I ask what your dimensions were?
Second question, the other cutter is 3" x 1/4" tipped with a keyway. Should I cut a keyway on the arbor to match or should I be able to get away without it :scratch:
Darren
Its quite obvious that the 5C collet, both indicators and the arbour are scrap. Please box them up and send to me for proper disposal. :lol: :lol: :lol:
Isn't it nice when a plan comes together. :ddb: :ddb:
Cheers :beer:
Darren,
I bought a range of different thicknesses of shims/spacers, so that I could mix and match to get to whatever dimension I wanted.
I can't give you the web address to order from, as they only take orders thru email after you have talked to their tech guys about what you want, but I managed to gumbeat them into taking a telephone order.
http://madmodder.net/index.php?topic=2142.msg22555#msg22555
Go a little further into the post and it shows how I set them up.
They worked out at less than 33p each all incl, and my order came to about 30 squid to get me a very good range of different thicknesses for the small dimensions I wanted to create.
Not wishing to waste my first attempt at making an arbor for the tipped cutter I decided to modify it to do another job.
As it was..
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/Slitting%20Saw/IMG_3921.jpg)
Turned the boss down to a tight one inch to match a couple of cutters I have
Carbide slitting saw
And a side and face milling cutter
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/Slitting%20Saw/IMG_3924.jpg)
The end was cut off, drilled and threaded. Next job was to make an end cap to fit.
I forgot to take a picture of it assembled, but I'm sure you can guess what it looks like.
(http://i401.photobucket.com/albums/pp92/thebodger/1024/Milling%20Tool%20Holder/Part2/Slitting%20Saw/IMG_3925.jpg)
Saved wasting a good bit of material :)
Nice one Darren :clap: :clap: It's great to find a use for those pieces that didnt turn out as you planned :thumbup:
Tim
