Gallery, Projects and General => Project Logs => Topic started by: Andrew Wildman on February 02, 2016, 03:57:07 PM
Title: milling vice restoration
Post by: Andrew Wildman on February 02, 2016, 03:57:07 PM
The vice that I use on the Omnimil is a bit shabby looking, has had a number of mishaps in the past (not me!) and could do with a rebuild.  I thought about getting a new one from Arc but the budget has to be spent on other things so I am going to tidy it up and make sure it is all square and true.
Here is the lump in all it's glory:
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/001.jpg)
Over the next few weeks I will strip it down, fill the holes with epoxy metal, scrape it true, fit new jaws and give it a lick of paint.  I still have a couple of other projects to complete so progress will not be particularly quick but here goes...
Title: Re: milling vice restoration
Post by: leg17 on February 02, 2016, 09:35:02 PM
You can probably R&R those jaw inserts.
Post by: Arbalist on February 03, 2016, 12:39:13 PM
I had an Abwood like that, should never have let it go when I sold the mill. Can you not get someone to fill the holes with weld for you?
Post by: Andrew Wildman on February 05, 2016, 03:45:22 PM
Leg17,the jaws have been milled lower than the main body of the vice so they really need replacing. I don't think they are original.
Arbalist, I did think about welding up the holes myself, but the main one is quite big and I don't want to distort the vice. The epoxy metal solution is not as nice but I think it will be sufficient to stop stuff dropping into the holes. What do you think about weld distorting the vice?
Post by: awemawson on February 05, 2016, 04:00:40 PM
Andrew, before I had my Bridgeport table re-ground a few decades ago, I (perhaps rather foolishly) had some 'oops dings' by the previous owner welded up professionally. They did all the right things, creating a large pre-heat brick enclosure, used the right nickel rods, and let it cool very slowly. Looked ok until it was finish ground, then the welds looked pretty awful  :palm: OK I probably notice them more than others would, but I keep them covered by a darn great vice most of the time  :lol:
Can you not fabricate a dovetail insert from cast iron to replace the bit with those holes - I'm imagining a bit with a lower dovetail to lock it to the body of the vice, and an upper one to match what is there (but without the holes!)
Post by: chipenter on February 05, 2016, 04:52:03 PM
Just key them and fill them then keep the vice shut , I used sperglue and ci dust stood up well so far .
Post by: Arbalist on February 06, 2016, 05:23:27 AM
I'm not the one to ask about weld distortion, just seen it done on another vice someone refurbed.
Post by: RobWilson on February 06, 2016, 05:57:09 AM
Like Andrew mentioned weld repairs on cast Iron look really awful unless painted and can also be problematic when it comes to machining the welded area  back .
Personally I would go with one of the two better options   ,your   idea to fill the holes  with some epoxy material  or as Andrew mentioned just machine off the dovetail and bolt on a new .
I have a few Elliot machine vices and they are all steel construction with a separate steel dovetail .
Cheers Rob  :dremel:
Post by: nrml on February 06, 2016, 09:02:53 AM
In the past, I have filled an accidentally drilled hole in a mild steel project with  soft solder. I melted in enough solder to fill the hole and dome above the level of the surrounding steel. I then pounded it flat with a hammer after cooling to fill all the little nooks and crannies at the edge of the hole and sanded it flat. The resulting plug was a different colour from the surrounding steel but it still looked like an exceptionally good repair cosmetically.
The hole I filled was smaller and deeper than yours, but it might work well on your vice. If it doesn't work, you could very easily remove the residue and revert to the ever trusty JB weld. All the JB weld fillings I have done  have been an eyesore but that might be down to me.
Post by: awemawson on February 06, 2016, 09:36:33 AM
Someone mentioned cast iron dust in super-glue - I'd be interested in pictures to see how that looks as it sounds fairly universally applicable by choosing the appropriate filler metal.
Post by: mattinker on February 06, 2016, 11:19:00 AM
It doesn't look like too big a hole, how about drilling it out tapping and putting a steel plug in it? The two smaller holes could also be fixed this way.
Regards, Matthew.
Post by: chipenter on February 06, 2016, 01:55:33 PM
It goes blacker with age One of the half bits got knocked off last week lasted over five monthes .
Post by: awemawson on February 06, 2016, 01:58:46 PM
Thanks Jeff - yes that looks rather like the table on on my Bridgeport. Still functional though  :thumbup:
Post by: Andrew Wildman on February 06, 2016, 03:58:24 PM
While I was waiting for paint to dry on the die filer I had a potter about with the vice.  I decided to mill a pocket and Loctite a piece to fit.  Here is the result.  In hidsight I should have just made the pocket square, this would have saved a lot of effort.  the other smaller holes are filled with epoxy metal.  The bit was a light press fit on the width and height so with the Loctite I don't think it will go anywhere.
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/001_1.jpg)
Once the adhesives are dry I will skim it and scrape it all flat.  I got to use my new tool that arrived in the post this morning.  Anybody else use a similar endmill/face mill?  It worked well in cast Iron.  BTW the equally crusty vice in the picture is the one for the AEW mill.
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/003.jpg)
Post by: tom osselton on February 06, 2016, 04:19:31 PM
This may be of interest to some looking at cast iron repair.
http://ezweldtigwire.com/about-ez-weld-tig-wire/
Post by: awemawson on February 06, 2016, 04:39:39 PM
I think one of the major issues welding cast iron by any process is getting it clean. Being relatively porous it will have absorbed all sort of oily grungy stuff.
Received wisdom is to bake it at quite an elevated temperature for several hours, but even then there will still be contaminants in it, and it risks distorting the casting.
I've had most success using 'sifbronze' rods and oxy-acetylene with pre-heat, but of course it will show as it isn't a colour match for the iron.
Perhaps it would have been feasible  to bronze weld it, then clean up well and give it a light nickel plating to give a uniform appearance.
Post by: Andrew Wildman on February 07, 2016, 05:34:49 PM
so I skimmed the vice until the insert was at the level of the surrounding metal, although wear is evident at the sliding end of the vice.  I decided not to go any further on the mill.
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/001_2.jpg)
Measuring the flatness shows about 0.002" wear that I will take out by scraping.  That does not sound like much but after an hour I have an aching arm and still have about 0.0005 to go! :bang:  I will post pics when flat
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/003_1.jpg)
Post by: Arbalist on February 08, 2016, 05:59:24 AM
Looking good so far. I do hope you're not going to put Hammerite on it though unless it's the smooth stuff!
Post by: Andrew Wildman on February 08, 2016, 07:48:27 AM
Ive got a bit of magnolia dulux left over from the kitchen! :D
Post by: Andrew Wildman on February 08, 2016, 05:04:18 PM
I finished scraping the bottom of the vice.  It is about 0.0002-0.0003 off flat which is good enough for the bottom of a general machining vice.
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/002_1.jpg)
I do like that with a few basic tools you can scrape surface to a very high geometric accuracy (much better than I have done here).  all it takes is a bit of patience and a bit of elbow grease.
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/001_3.jpg)
Post by: Spurry on February 08, 2016, 05:18:57 PM
V nice work Andrew.  :thumbup:
Post by: RussellT on February 09, 2016, 03:40:30 AM
Looks good - and hides your repair well.
Post by: RobWilson on February 09, 2016, 04:28:54 AM
Nicely done Andrew  :thumbup:
Post by: RotarySMP on February 09, 2016, 09:36:45 AM
A tool to be proud of.
Mark
Post by: Arbalist on February 09, 2016, 02:12:20 PM
Very nice job. It'll need some of that Dulux soon!
Post by: millwright on February 09, 2016, 02:54:32 PM
Nice restoration Andrew, those Sandvik scrapers do make a lot of difference as well. Ive had mine over 30yrs fortunately they were bought by the company and left with me when i was made redundant.
john
Post by: Andrew Wildman on February 14, 2016, 04:27:47 PM
John, I baulked a bit at the £50 odd quid it cost me but it saves a lot of time sharpening carbon steel scrapers, you soon forget the cost!
I made some transfer screws out of some whitworth 12.9 screws that were in the 'misc whitworth' drawer.  I quenched them but I am not sure it made them any harder.  They served there purpose anyway.
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/001_4.jpg)
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/003_3.jpg)
I made up some new jaws out of (what the Americans call) O1, mainly because it is pre ground stock.  I may harden and temper the jaws, depending on whether my experiments show that I can do it without twisting them up like a pringle.  The jaws will be milled in situ so I stamper them up f for fixed and s for sliding so that if I remove them I can put them back in the right place.
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/002_2.jpg)
Post by: Andrew Wildman on February 14, 2016, 04:28:43 PM
I filled the castings and slapped on a bit of paint
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/004.jpg)
Post by: Arbalist on February 14, 2016, 04:42:11 PM
Nice paint job!  :thumbup:
Post by: Andrew Wildman on February 24, 2016, 04:59:09 PM
I assembled the vice.  The only bit left to do is experiment on heat treating the spare bit of ground bar I have to see if it warps.  I think my tool cum surface grinder is too small to grind the jaws flat again if they do warp.
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/003_4.jpg)
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/002_3.jpg)
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/001_5.jpg)
Post by: RotarySMP on February 26, 2016, 07:14:42 AM
Very nice restore. What is next? The mill it sits on?
Mark
Post by: Arbalist on February 26, 2016, 01:37:53 PM
Nice work and good paint job!
Post by: millwright on February 26, 2016, 02:26:49 PM
A nice job Andrew it looks as good as new.
Post by: Mark Rand on February 26, 2016, 07:18:21 PM
Sorry for the late question, but did you check and scrape the base, if necessary, before scraping the ways?
Post by: Andrew Wildman on February 27, 2016, 05:31:23 AM
Mark, the old mill needs a bit of a makeover.  Possibly a job for the future.  I did rebuild the vertical downfeed mechanism on the quill when o got it.  Three of the gears had lost their teeth and one of the shafts was bent! Works well now though.
Mark Rand, I only stoned the base as it was fairly flat.  I did not want to take any material off the base as it would have messed up the fixed jaw alignment to it.  The top of the vice had worn or been peened to death by people hammering parts down so it needed resurfacing.
Post by: Andrew Wildman on February 28, 2016, 02:34:03 PM
The shed now smell of chips thanks to my heat treatment experiments  :ddb:.  I heater a spare piece of the plate to above its curie temp (so it was no longer magnetic) and kept it there for 20 mins.  I then quenched it in veg oil.  The plate is currently in the oven (in the kitchen!) at 240 deg for 1 hour.  I have not checked for straightness fully after quench but after a quick eyeball it looks ok.  Here is the forge in full heat.  The bog brush holder on the ground is my quench tank.
(http://i1031.photobucket.com/albums/y373/dreeewman/vice%20restoration/002_4.jpg)
I will clean up tomorrow and see if it is straight and if my talcum powder/meths anti-scale worked.
Post by: millwright on February 28, 2016, 02:59:58 PM
Looks like an ex schools Flamefast brazing hearth there Andrew, does the torch run on the flow gas ok or did you have to alter it?
Post by: Andrew Wildman on February 29, 2016, 11:33:56 AM
John, it's a bye such is very similar to the flame fast. Ex school. I purchased it already converted for propane. Does a good job, but didn't cost me much
Post by: millwright on February 29, 2016, 03:17:26 PM
That sounds like you got a good deal Andrew, a nice bit of kit,
