The Shop => Electronics & IC Programing => Topic started by: DavidA on May 30, 2013, 03:11:08 PM
Title: single phase motors.
Post by: DavidA on May 30, 2013, 03:11:08 PM
Is there anything on the site about how to fit a reversing switch to a single phase mains motor ?
I need to make my lathe go in reverse for screw cutting. I'm using a 1 HP motor as bought from Machine Mart.
Title: Re: single phase motors.
Post by: doubleboost on May 30, 2013, 04:22:33 PM
You can get a switch from ebay that comes with detailed instructions
http://www.ebay.co.uk/itm/SINGLE-PHASE-1PH-MOTOR-REVERSING-SWITCH-REVERSER-ENCLOSED-1PHRE-/281103644721?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item4173153831
Not sure if machine mart do one or not
Post by: BillTodd on May 30, 2013, 05:20:23 PM
Essentially, the start/run capacitor is switched between the live and neutral - its other terminal is connected to the start winding.
On a motor with a start only capacitor (these usually have centrifugal switch to disengage the cap once the motor is spinning), it's usually necessary to stop the motor and restart in the reverse direction. Motors with continuous start/run caps, ( often small motors) the motor will reverse as the cap is switched.
Post by: DavidA on May 30, 2013, 06:58:05 PM
John,  Bill,
Thanks.
I'll be ordering one of those switches tomorrow.  It will certainly be better than moving the saddle back along the bed by hauling on the belt.
Post by: vtsteam on May 31, 2013, 08:48:32 AM
I've always wondered about lathes that have a separate rack (as my Craftsman does) besides the lead screw and half nut and no tumbler reverse. Why the rack at all?
My Gingery lathe had no reverse, but it also had no rack so releasing the half nut released the slide to be positioned as easily as the tailstock is -- just slide it to where you want it. In fine adjustments or screw cutting without the indicator (not that I had made change gears yet) you could just release the motor drive and rotate the lead screw backwards with a ball handle at the end of the screw. It was very simple and very fast to work with.
I find the rack and wheel on the Craftsman clumsy -- fair amount of backlash -- very coarse adjustment virtually requiring a additional lathe stop or gauging setup to cut to a dimension, and slow to traverse the carriage compared to releasing it and sliding by hand. I can see the need for something like that on an industrial size lathe where the carriage is massive and needs a handwheel to budge it or the bed is very long. But on a small home workshop lathe? Perhaps it's just a bit of sales appeal to look like the big boys. Apologies if I'm missing something...
Post by: DavidA on May 31, 2013, 02:23:26 PM
vtsteam,
... you could just release the motor drive and rotate the lead screw backwards ..
You can't do this when screw cutting unless you have an indexer to show you where to drop the half-nuts back into mesh with the leadscrew.
If you disengage the mandrel you will lose the synchronization and your thread will be,well, screwed up.
Post by: vtsteam on May 31, 2013, 02:44:38 PM
Hi David, releasing the drive on the Gingery lathe means pulling the layshaft and motor assembly forward to slack the belt, not disengage the change gears.
Also, the Gingery change gear construction does include an indexer build.
Post by: DavidA on June 01, 2013, 07:09:12 AM
vtsteam,
Thanks for clearing that up.
If I cut small threads on my lathe (say 20 tpi) I leave the gear train in normal drive and then cut the thread by hand using the crank handle plugged into the end of the mandrel. This is ok for most modeling work.  But if I need to cut,say, 8 tpi it gets a bit tiring and I engage the back-gear and cut under power. The back gear and the lowest speed on the pulleys is about right for threading.
The problem is that it is almost impossible to wind the saddle back using the crank when the back-gear is engaged.
So I ordered the reversing switch and it arrived about an hour ago.
Now I just have to identify the wires on the motor.
Post by: DavidA on June 04, 2013, 06:58:04 PM
Well, as I mentioned above,  I now have the switch.
The instructions are not quite as 'detailed' as doubleboost suggested but I am reasonably confident with the diagram
One point. Identifying the start windings.
The motor had two pairs of wires that disappear into the windings.  Both pairs consist of a red and a white wire.  I assume one pair is the start winding.
Question.
Is it the pair that has it's white wire connected via a condenser to the neutral supply (blue wire) ?
Post by: vtsteam on June 04, 2013, 09:57:33 PM
Colors are often arbitrary --  one bit of the puzzle -- start windings have higher resistance and are thinner wire than run windings. Can you identify that much?
Post by: DavidA on June 05, 2013, 07:24:06 AM
vtsteam,
I'm trying to add a sketch of the wiring to the post.
I've measured the windings and get 26 Ohm for the red winding and 21 Ohm for the white winding. So by your reckoning the red one should be the start winding.  But the capacitor is in series with the white winding.
The motor,  in case anyone has a similar set-up,  is a Clarke 800/4  1350 rpm  1HP .
I've managed to get the sketch as far as photobucket. just got to link to it.
Post by: vtsteam on June 05, 2013, 07:41:37 AM
There are run capacitors and start capacitors, also a throw out switch. Also sometimes there are wires for reversing and different speeds, and colors are almost never standardized. It's hard to tell just from a word description. For instance when you measured resistance was the throw out switch engaged? Were the two windings therefore paralleled? Or are the switch and leads brought out.? etc.
Post by: DavidA on June 05, 2013, 07:45:58 AM
(http://i437.photobucket.com/albums/qq93/klixon/motormcircuit_zps19a48235.jpg) (http://s437.photobucket.com/user/klixon/media/motormcircuit_zps19a48235.jpg.html)
Here's hoping this has worked.
Post by: DavidA on June 05, 2013, 07:50:32 AM
vtsteam,
Looks as if our posts crossed.
I don't hear any throw-out switch operating. So I don't think there is one.
I'll just have to try various connections and see what happens.
Unless,  as I mentioned above,  someone else has already done the same thing to hte same motor.
Post by: DavidA on June 05, 2013, 07:56:41 AM
Bill,
...Essentially, the start/run capacitor is switched between the live and neutral - its other terminal is connected to the start winding.
This is starting to make more sense to me as I think about it. I am thinking that the winding with 21 Ohm reading (the white winding) is the start winding.  So I will have to keep the capacitor connected to that one.
The new switch will be switching the capacitor between the live and the neutral supply.
Post by: Pete. on June 05, 2013, 08:04:02 AM
Some motors have no switch, they run on both windings permanently.
Post by: Bluechip on June 05, 2013, 08:35:55 AM
Is this a new motor ??
There should be a connection diagram with the motor, often inside the access cover.
Why not ask Machine Mart ???
Just guessing which winding is  which , is it cap start, cap start/run, split phase etc. etc. is nonsense.
Dave BC
Post by: DavidA on June 05, 2013, 09:49:53 AM
Bluechip,
The motor was new about a year ago.  There was a instruction with it for how to change the direction of rotation if it was incorrect for your application ,  However, this has long ago disappeared.
I had to reverse the direction when I fit it to my lathe. But can't remember how I did it.  It has worked as it should for the last twelve month.
...Just guessing which winding is  which , is it cap start, cap start/run, split phase etc. etc. is nonsense...
Of course it is. It is also dangerous and can lead to damage,  My philosophy is never press a button unless you know what is going to happen. Or at least what should happen.
I am not intending to just connect random wires and hope for the best.  My first serious job was as an apprentice industrial electrician. Were this a three phase motor I would be completely at home.
The motor will start and run using only the red winding. It won't start using only the white winding.
I may indeed try asking Machine Mart about this.  But I was hoping that someone here may know. I suspect that MM will say 'we just sell them'.
I notice that Doubleboosts miller appears to have a similar motor attached.
The only real concern I have is in positioning the capacitor.
I suspect that the changing of the capacitor from line to neutral alters the phase lead in the start winding which dictates the direction of rotation.
Post by: Bluechip on June 05, 2013, 10:01:46 AM
David
MM do have a technical helpline number.
I have used them years ago for a pressure cut-out switch.
Very helpful and told me which one to get.
Not the one I thought was right ...  :scratch:  but one which was right.
If you don't ask, you won't know.
Not even premium rate.
http://www.machinemart.co.uk/pages/customer-service (http://www.machinemart.co.uk/pages/customer-service)
Oooops now a 0871 used to be Nottm. Exchange
Dave BC
Post by: Rob.Wilson on June 05, 2013, 12:51:40 PM
Hi Dave
I am a bit late to the party  :Doh:
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060774~0.jpg)
(http://www.nam-engineering.com/cm/albums/userpics/10002/normal_P1060775.jpg)
The dotted lines are link bars , If your fitting FW/REW switch you remove these completely .
Post by: DavidA on June 05, 2013, 03:44:20 PM
Here is the supplied diagram and my proposed connection to motor.
The connection to the motor are exactly as Rob's picture shows.
Post by: Rob.Wilson on June 05, 2013, 03:51:11 PM
Looks good to me Dave  :thumbup:
Rob  :zap:
Post by: DavidA on June 05, 2013, 04:02:56 PM
Rob,
Thanks.
Anyone find a problem with it before I wire it up,  switch it on ,  and shut down the national grid ?
(Note to self: Wife needs to buy me a single to three phase converter this Christmas)
Post by: DavidA on June 06, 2013, 05:02:27 PM
As it turned out there was a problem.  Motor ran forward,  but not backward.
After a couple of checks of the wiring I striped off all the switching and re-assembled as a single direction motor just using the old start button.  It ran with no problem. Even in reverse when I had changed the straps around.
There was nothing wrong with the way I wired the switch.  double checked it.
So I have come to the conclusion there is an error in the supplied wiring diagram.
Anyway,  I know how it should be wired thanks to some of you guys. Earlier today I traced all the connections on the reverser switch and it is actually comprises of 16 single pole switches. Eight work for the forward motion and eight for reverse. Lots of links needed.
I'll let you know exactly where the problem was when I find it.
One chunky double pole double throw switch would do the same thing as this ghastly thing.  Cost me a fortune.
Post by: Bluechip on June 06, 2013, 05:37:25 PM
Alas! Probably not  :(
If you reverse the connections to the start winding/capacitor while it is still running the chances are it will just slow down and growl at you without changing direction, unless it kicks out a breaker.
What you need the switchery to do is:
(1) Remove all power to the motor until it has stopped.
(2) Change sense of start winding. ( Or run )
(3) Re-apply power.
Dave BC
Post by: DavidA on June 07, 2013, 07:03:57 AM
Dave,
I burnt a bit of midnight oil an and managed to work out how the switch should be wired.  So now it works correctly.
The secret seems to be that the run winding needn't be switched. It stays the same in both forward and reverse.
So, switching the start winding becomes  a simple change-over switching operation.
As it's wired at the moment I don't have a centre off position on the switch.  Two forwards and a reverse. I know why this is but as I will be turning the motor on and off with the zero-voltage stop-start switch it doesn't matter.  Most of the time I will be in forward for normal turning. I do know how to fix it,  but have had enough of switches for the time being.
Post by: Bluechip on June 07, 2013, 07:35:25 AM
That's right, one winding is always 'On'. ie. Not switched.
Just 'end for end' the other one. Doesn't matter which, but usually the start winding.
But if the motor is running and you just change over the start winding the 'run' usually wins and the motor now has the run winding going one way and the start trying to go the other.
As that winding is in series with a capacitor it's current is restricted by the reactance of the cap, so it doesn't have the guts to do much. ( If it's 10uF the Xc is some 318 ohms @ 50 Hz).
Did a cap. run motor 3-4 years ago 330W for a mate ( drove an extractor fan ) someone wired it up just with a DPDT switch and it didn't reverse. Just went slower and growled a bit .. so I cobbled up a box with 2 switches and told him to switch it off, change direction, switch it back on. A bit clumsy but it did the job.
He was then able to have a blow or suck as circumstances required.
So, if you have a 'NVR O/L Stop Start' wotsit you're in business ... :thumbup:
Dave BC
Post by: DavidA on December 30, 2014, 03:02:13 PM
Dave BC,
Way back in this post you remarked...Why not ask Machine Mart ???..
Today,  I was messing about with the switch again and just out of curiosity I emailed Machine Mart.
They replied with two diagrams within three hours.
Credit where it is due.
Dave. :thumbup:
Post by: DavidA on January 20, 2015, 07:44:26 AM
Yesterday I had reason to go to Bradford and decided to call in Machine Mart and see if they had one of the electric motors that I am using in stock.  My aim being to ask to look in the contact box and see how the thing was wired up.
I still had the receipt for the original purchase back in July 2008.
They didn't have one there, but had a similar motor which they allowed be to look at.
But more interestingly,  when the assistant typed in the code for the motor he said that they were marked down for discontinued line. And that they would be replaced by a different one.
Now,  the good bit.
The motor was still available for £23 +vat. (£27.60). Would I like one ?
Now , the original cost me £76.36 inc vat. The new version is going to cost £95 +vat.
Sure I would like one. It seems they are held at Some place in the midlands,  and it will arrive at Bradford next Monday. I will have to collect it as from there. No sweat.
So,  If you want or will be needing a single phrase 1 HP motor then ring MM and tell them you would like to know if motor code number 010210080 description motor 1 - 4 - 1 BOF is still available.
For £27.60 you can't go wrong.  Just don't order the new expensive one by mistake.
You will have to collect from you nearest MM.
Post by: hermetic on February 27, 2015, 04:23:15 PM
Just to clarify a few points here chaps, to reverse any single phase motor, you reverse the polarity of the start winding, this is often marked as Z1 and Z2, but with motors coming in from all over the globe, your experience will probably vary! It doesnt matter if the start winding is just a winding, a winding and a capacitor, or a winding a capacitor and a centrifugal switch, if you treat the whole circuit as "the start winding" swap the wires over where it connects to the live and neutral, and the motor will reverse. As correctly stated above, a single phase motor on the run winding will operate in either direction, if started without the starting circuit and spun by hand, it is the start winding that gives a directional kick to the motor, reverse the kick, and you reverse the motor. As the OP has already discovered, the clever bit is linking the reversing switch so that it does this, and they are all different. You should always allow the motor to stop before reversing it, or you risk damaging the start winding.
Post by: Arbalist on February 27, 2015, 06:25:35 PM
Many years ago someone gave me a motor of around 1/2 HP for a small Lathe I had and no matter which way I wired it, it would only run one way. I asked the guy who gave it to me about this and he said some motors can't be reversed. Is this correct? It wasn't a problem for me as I was able to physically mount the motor the other way round!
Post by: Manxmodder on February 27, 2015, 09:45:11 PM
I had a similar situation a few months back,a mate gave me a brushless ac motor to put on a small bench drill.
It had the wrong rotational direction and to correct it I had to press the rotor of the shaft and press it back on the other way round. Just reversing the whole rotor assembly would have worked but the keyway in the shaft would have ended up on the wrong end of the motor......OZ.
Post by: hermetic on March 07, 2015, 09:51:46 AM
Hi Arbalist, yes it is correct that some motors cannot be reversed, because the manufacturers "hide" the wires or connections you need to do the reversing. It also happens with motors like the old fashioned shunt universal (AC/DC) motors where you have to reverse the brush holder connections.........but the wires arent long enough!! If you are willing to tear the motor to bits and extend/alter wiring, you can usually do it, but it is more sensible to get another motor.
Post by: DavidA on September 30, 2019, 04:32:27 PM
Hi,  doing a bit of dead thread resurrection.
I happened to be wondering why the motor (subject of above posts) gets so hot when running.
Could it be because the because the start winding and it's associated capacitor are always in circuit ? And thus are across the run winding.
I was thinking that the phase difference between the two windings may be causing the heating.
Perhaps a modification to cut the start winding out when the motor is running would be beneficial, what are your thoughts ?
Post by: vintageandclassicrepairs on September 30, 2019, 05:15:46 PM
Hi David,
In my experience (35+yrs) I have never seen the run winding with a higher resistance than the start
so I think the capacitor is connected to the wrong winding ????
Have you measured the current when the motor is running and compared it to the data plate?
No load amps will be much lower than full load, but incorrectly connected amp readings will be higher
Of course cheap imported motors will not have top quality lamination's and these will run hotter
There maybe a temp rise figure on the data plate ?
Post by: DavidA on October 01, 2019, 03:23:01 PM
Just been looking through my notes, and I also see a reference to the start winding being higher resistance to the run winding.
At the moment I have the wires disconnected from the motor terminal block as I was doing some coil resistance measurements. But tomorrow I will re-connect and see what the current draw is.
My thinking was that as it appears the two windings are in parallel (with one winding having the capacitor in series with it), the winding with the capacitor would be 90% out of phase with the other.  OK for kick-starting the motor, but maybe not so good for continuous run.
I'll get back tomorrow and let you know what I find.
Post by: DavidA on October 02, 2019, 02:00:17 PM
Well, I ran a few checks, I have come to the conclusion I am worrying unnecessarily.
The motor plate states 230 Volt, 1 HP at 5.6 Amp.
I measured a mains supply of 247 Volt (checked that with another meter, it's correct) and a current of 4.87 Amp.
The above is no-load.
Motor sounds ok. I dismounted it from the lathe and ran it on the bench.
Also found out that it will start and run without the start-winding and capacitor in circuit. But it draws more current (6.64 Amp) and the direction of run is random.
So, I'll clip my thermocouple meter to one of the fins and run it for an hour on the bench to check the temperature does not get too high. Then bolt it all back on the lathe.
Post by: vintageandclassicrepairs on October 02, 2019, 07:34:51 PM
Hi David,
Some motors will get hot(ter) when run free
No mechanical load can mean the motor will run nearer synchronous speed so then they do not generate
a back EMF to reduce the current (well thats my theory)
I hope that makes sense, its not in any information I have read just something I have found out over the years
Post by: ZebraDriver on October 09, 2019, 08:50:54 AM
Just to add a bit to this thread.
 Most small 240 volt AC motors are capacitor start. They normally have a single capacitor and a centrifugal switch that drops the capacitor and the start winding out of the circuit once the motor has reached running speed. The switch can usually be heard closing again (with a "click") once the motor has been switched off and runs down.  To reverse this type of motor all that requires to be done is to swap the live and neutral feed to the start winding/capacitor, whilst maintaining the live/neutral unchanged to the run winding. Some motors have a set of links within the terminal box (usually in a "L" shaped configuration) that allows you to select the required rotation direction. Some motors have a permanent connection but a bit of detective work will let you find the right winding ends to swap, but please be careful to make sure that you have the right type of motor (and there are several different types !) and the right winding ends before you attempt any reversal work.
If you have the type of motor mentioned (with a centrifugal switch) then a simple on/off/on two pole toggle switch can be used as a reversing switch. Simply feed live and neutral to the two centre contacts and then wire one end of the switch to feed the start winding /capacitor. Wire a pair of cross over wires between the four outer contacts, these will feed the motor/capacitor with a reversed supply for running in the opposite direction. The switch can be operated when the motor is running as it will have no effect (because the centrifugal switch will already have switched the winding and capacitor out of the circuit), it will only take effect when the motor is re-started.
The comments regarding motor heating are consistent with a single phase motor that we fitted to a customers machine recently. The motor would run quite hot (but within its design temperature) if it was working at full load or at no load. We were concerned and the supplier gave us a further two motors to test, both of them gave the same results. The motor manufacturer was given the two motors back and as yet have not explained the temperature rise, but we did note that the current drawn when running without load was only slightly less than the full load current.
Martin
Post by: Muzzerboy on October 09, 2019, 09:53:44 AM
Hi David,
Some motors will get hot(ter) when run free. No mechanical load can mean the motor will run nearer synchronous speed so then they do not generate a back EMF to reduce the current (well thats my theory)
Sorry - quite wrong there. At no load, the motor is indeed running close to synchronous speed but the back emf equals the source voltage. Apart from the magnetisation current and some copper losses, there should be minimal load current and heating.
If there is a significant current flowing under no load conditions, there is something wrong with the motor or the way it's connected. One vague possibility is that it's a lower voltage machine operating above its rated voltage. This seems unlikely but would result in higher magnetisation currents and possibly saturation of the laminations.
PS - to be fair, it's not very helpful to simply consider back emf when understanding how AC motors work. In reality, the magnetic field in the air gap is rotating at a fixed speed (the applied frequency divided by the number of pole pairs) and the rotor is trying to follow it.
In the case of a synchronous (permanent magnet) motor, the angle between the rotating field and the rotor varies proportional to the applied torque (in both motoring and generating), whereas in the case of an asynchronous (induction) motor, the rotational speed difference varies proportional to the applied torque (in both motoring and generating). In the induction motor, this difference in frequency is applied to the windings in the rotor, which in turn create a magnetic field which results in the torque. Without any slip frequency, there can be no induced rotor current and field. In both machines though, torque is proportional to current if you ignore magnetisation current which should be fairly constant
With a single phase motor, there is no rotating field of constant field strength as such, just a sinusoidally pulsating field. At stall, there is no torque available unless some additional mechanism is brought to play. If the rotor can be brought up to near synchronous speed, it can then develop a decent torque. There are various ways to create a phase delayed magnetic field which will result in a starting torque. A capacitor is one means and a "shading" winding is another. With a starting capacitor, the direction of the starting torque can be reversed by reversing the phase of the start winding.
Post by: vintageandclassicrepairs on October 09, 2019, 04:11:56 PM
Hi Muzzerboy and All,
It has been a very long time since I was lectured at college on motor theory  :smart:
so I got the theory incorrect :palm:
However
Practical lessons and experience do not always agree with the books !!
I have found the same issues as quoted on several occasions throughout the last 40 odd years
An example is a 1/2Hp motor I have used on a pillar drill without issues or overheating despite lots of  hard use
I was given this motor for free as on bench testing (without load) it would get very very hot
It does not even get warm when driving the drill for long periods
