%MPF 16 N0040 R10=0 (Starting Angle) N0045 R11=60 (Angle Span) N0050 R12=5 (Angle Step) N0055 R13=25.00 (Stock diameter) N0060 R14=10.00 (End Mill Diameter) N0065 R5 = R14/2 (Form cutter radius) N0070 R2 = R13 + R5 (Form D+R term) N0075 R1=R13+10 (Stand clear of bar) N0080 G71 G94 (Metric Feed MM) N0085 L54 (Go to safe toolchange posn) N0090 T9 D9 (10 mm 4 flute endmill) N0095 @714 (wait for buffer to clear) N0100 M23 (Power Tooling Anticlockwise) N0105 S1000 (1000 rpm) N0110 G01 Z100 F500 (Test away from stock) N0115 G01 X=R1 F500 N0120 M20 (Rotate to Target Angle) N0125 M19 S= R10 N0130 @714 (Wait for buffer to clear) N0135 @631 R3 R10 (Form cosine of angle in R10) N0140 R4= R2 / R3 (divide d+r by cosA) N0145 G01 X=R4 F100 (perform the cut) N0150 G00 X=R1 (stand clear of bar) N0155 R10 = R10 + R12 (Calculate next Target Angle) N0160 @123 R10 R11 K-120 (Loop Back if Span not exceeded) N0165 M30
