The Shop => Metal Stuff => Topic started by: DavidA on January 23, 2016, 06:53:47 AM
I'm used to using large industrial milling machines, but when it comes to my small tabletop machine I am a bit wary.
What would the group suggest as a reasonable speed (rpm) to run a 10mm HSS two flute cutter when cutting bright mild steel ?
I believe this material to be to EN3 spec. Non leaded.
Hi Dave,
According to FSWizard 1,640 rpm:
http://zero-divide.net/index.php?page=fswizard (http://zero-divide.net/index.php?page=fswizard)
Phil,
Thanks for that, and the link.
I looks as if you used 'very soft steel' as an input.
I suspect this stuff is a bit tougher, so I tried 'structural steels <0.5% Carbon.
I believe it is C15, or there about.
Gives me an rpm of 1380.
I guess the best thing to do is call in the steel supplier and ask them for the spec.
All I'm making at the moment is 'T' slot nuts. The machine does appear to be making hard work of it. There again, it is only a Micro Mill.
I might be hallucinating but I seem to remember someone quoting a rule of thumb for rate of metal removal (e.g. cubic inches per minute) versus horsepower (or Watts) at the tool. Maybe you're running out of horsepower?
Pete,
A possibility, but in this case I doubt it.
I'm only cutting 3mm wide and 0.5 mm deep.
Having watched Stefan Gotteswinter's video where he does a comparison between HSS and Carbide cutters
I don't think I should really have a problem.
My thoughts are that you are probably not using the correct cutter.
If you are using a 'slot drill' slot drill, you might try an end mill.
I've just been trying to sort out the goodies which came with my little Myford ML10 and found that whoever had owned the lathe used the faceplate and a single point tool to mill.
My suggestions might be wrong, however.
Norman
Norman,
You may be right, I am using a slot drill.
I admit that I didn't expect it to make a difference.
I always thought that the only real difference was that you could plunge with a slot drill, but not with an end mill, but it is certainly worth giving an end mill a try.
I managed to finish the 'T' nuts. It would appear that the main problem was that |I was being too gentle on the feeds and speeds.
I upped the speed to something around 1350 rpm (hard to tell, no markings; A cheapo tacho is on it's way) and fed it quite aggressively and this seemed to work.
It was a new cutter when I started, and towards the end the vibration was starting to tell me that the edge was going.
On removal, the very tips of the cutter were showing signs of wear, but the rest of the edge was ok. no apparent wear on the flutes. So really it needs sharpening before any further use.
The conclusion I come to is that it doesn't matter if it is an end mill or a slot drill as only the very tips do any cutting in normal milling.
And that when cutting anything tougher than leaded steel it may be worth getting a carbide.
You can't plunge with all end mills, some are not centre cutting.
Seadog,
Yes, I know.
See my response (#6 above) to Norman.
Dave,
If you haven't got a tool and cutter grinder just take the corners off on a bench grinder. A 45 degree (ish) chamfer with about 5 degrees clearance will give your cutter a new lease of life.
Phil,
That would be one way to go; thanks for the idea.
But as this is a very low power machine I really aught to aim for a nice crisp edge with minimal contact area.
I could take the cutters down to my old work and get them touched up.
As I am gradually 'rationalizing' my numerous time consuming pursuits (aka hobbies) and starting to get my machining into some kind of order, I have a cutter grinder pretty close to the top of my wish list.
Meanwhile I may have a go at H Hall's grinding rest.
Phil,
Going back to the original reason for me creating this thread.
I just received my copy of 'Milling:a complete guide' by Harold Hall.
I think that all of the items he covers in the book have also been presented in Model Engineer's Workshop; but I reasoned that it would be more convenient to have all this stuff in one place.
The items covered and the techniques used are very interesting,
But what immediately struck me was the speeds he uses.
He is recommending free cutting mild steel for his projects. But running a 12mm HSS cutter at 500 rpm.
Agreed, he does indicate that there is some leeway in this, but 500 rpm is less than half the recommended speed.
I do tend to wonder if many people have taken this advice too literally and wonder, as I did, why they were having problems milling with small cutters.
At lower speeds less heat is generated and the cutting edge lasts longer , and you don't need to use coolant .
Jeff,
I appreciate the above points.
However, it would perhaps be a good idea to point out to the reader that the speeds used are not the same as the ones to be found in standard tables.
After all, the book is entitled 'MILLING; a complete course'.
Everyone eventually accrues a collection of "rules of thumb". Some lead to argument but that doesn't matter if it works for you.
One that I picked up years ago was 0.500" = 500 RPM. This is a good starting point for milling and drilling mild steel with HSS. Since RPM to diameter is linear you can easily do the math in your head for others. Double the diameter, half the speed. Half the diameter, twice the speed... etc. You quickly learn to look and listen and watch and adjust accordingly. Oh, and for carbide I typically double or triple the RPM.
Running slower will, for the most part, take longer and make the cutter last longer. Tool books will usually give production speeds that get the job done quickly at the cost of quickly wearing tooling.
On a manual machine I mill and drill stainless much slower than suggested. I get excellent results.
Best way to learn is to get some sharp HSS cutters tharent too expensive. Start with book values and adjust both ways to see what happens.
I should also add that I use a rubber puffer for small cutters , cutting it's own chips will knock the edge off if not cleared .
