The Shop => Our Shop => Topic started by: chipenter on October 19, 2015, 03:10:56 PM
Title: LED Downlightes
Post by: chipenter on October 19, 2015, 03:10:56 PM
I found LED downlights in Poundland http://www.poundland.co.uk/home-and-pet/around-the-home/lighting-and-electrical/gu10-led-bulb bought one to try , I have a few of these lighting my mill and lathe and if you can get them close to the work they provied plenty of light , will be getting more of these cheap to run lights .
Title: Re: LED Downlightes
Post by: MadModder on October 24, 2015, 10:57:54 AM
I was kind of chocked at first looking at the installation on your first picture, after following your link.
But then I saw that one is not GU10. More like GU5.3 for 12V.   :thumbup:
Post by: chipenter on October 24, 2015, 01:10:04 PM
The lights have sort of evolved most are 12 volt the fist picture is , the last pick is the gu10 at 240 volts , with all five on I use 10.8 watts and nothing gets hot .
Post by: MadModder on October 24, 2015, 09:02:14 PM
Yes LEDs are pretty remarkable. Saves you not only from burning yourself, but also from burning a hole in your wallet while sheding some light over the workpieces. :D
