The Shop => Metal Stuff => Topic started by: sbwhart on July 29, 2018, 06:02:57 AM
Title: Friction Turning a Smoke Box Door
Post by: sbwhart on July 29, 2018, 06:02:57 AM
Hi I thought this would be of interest to you chaps. Friction Turning a Smoke Box door for a 5" Gauge Loco. Basically what I've done is covered the face plate with masking tape and trapped the door up against the face plate using a running centre the friction gives enough drive to enable you to machine across the face.
This video will shows you how.
Title: Re: Friction Turning a Smoke Box Door
Post by: John Rudd on July 29, 2018, 07:04:18 AM
Stu,
Thanks for sharing....I guess the masking tape provides sufficient grip to hold the plate against the backing plate without slippage?
Post by: sbwhart on July 29, 2018, 07:34:40 AM
Stu,
Yes John:- what you're doing is giving it a better coefficient of friction compared to steel on steel, I know some people who have used double sided sticky tape or even supper glue but that leaves you with the problem of getting the job off the plate I've found that masking tape is more than adequate, the running centre is keeping it in place it can't fly off the worse that can happen is that it starts to slip if you try taking too large a cut.
Post by: vtsteam on July 29, 2018, 08:41:36 AM
That's a very useful tip. I'll definitely be remembering that for the future!  :clap:  :beer:
