Home Base => Announcements & Issues => Topic started by: Ginger Nut on May 02, 2015, 07:57:58 PM
I am having a problem with emailed notifications of late, this has happened in the past but usually it clears up after 2 or 3. Now its everyone I receive.
Here's the result
"This Connection is Untrusted
You have asked Firefox to connect securely to madmodder.net, but we can't confirm that your connection is secure.
Normally, when you try to connect securely, sites will present trusted identification to prove that you are going to the right place. However, this site's identity can't be verified.
What Should I Do?
If you usually connect to this site without problems, this error could mean that someone is trying to impersonate the site, and you shouldn't continue."
Technical Details
madmodder.net uses an invalid security certificate.
The certificate is not trusted because it is self-signed.
The certificate is only valid for Parallels Panel
The certificate expired on 24/10/2012 03:52. The current time is 3/05/2015 09:54.
(Error code: sec_error_unknown_issuer)
I can only then use my bookmarked link to Madmodder main page to gain access.
Ray
Hi Ray,
Had the same for all https sites, here is what worked for me.
https://support.mozilla.org/en-US/kb/connection-untrusted-error-message#w_the-certificate-is-not-trusted-because-the-issuer-certificate-is-unknown
Abraham
Thanks Abraham will look into that.
