The Shop => Finishing => Topic started by: Yorkshireman on August 25, 2009, 07:47:33 AM
Title: polishing machine
Post by: Yorkshireman on August 25, 2009, 07:47:33 AM
I once made me a small polishing contraption from an old printer, quick and dirty. I used the powersupply from an old mobile.
These jamjars with 6 corners do work well for small pieces. I used this to create a uniform surface before applying pimer and paint.
As the polishing granulate I've tried: cat litter, steel chips, pieces of quartz etc and a granulate from walnut shells.
One has to find the proper conditions by trial and error. Polishing time can be up to 24 h.
Johannes
(http://i76.photobucket.com/albums/j35/jgleeds/th_rot002.jpg) (http://i76.photobucket.com/albums/j35/jgleeds/rot002.jpg) (http://i76.photobucket.com/albums/j35/jgleeds/th_rot003.jpg) (http://i76.photobucket.com/albums/j35/jgleeds/rot003.jpg) (http://i76.photobucket.com/albums/j35/jgleeds/th_rot004.jpg) (http://i76.photobucket.com/albums/j35/jgleeds/rot004.jpg)
Title: Re: polishing machine
Post by: Darren on August 25, 2009, 07:52:11 AM
Excellent....I really want to make a polishing machine....or tumbler....and I have an old printer I could use.
Thanks for posting, would never have thought of using a printer...... :thumbup:
Did all the parts come from the printer....?
Post by: Yorkshireman on August 25, 2009, 08:00:16 AM
Yes, they did. I modified the position of one of the two axis to get them to the same height.
You have to ensure that both the axis are driven and that they do turn into the same direction, OK?  :thumbup:
Post by: Darren on August 25, 2009, 08:04:59 AM
Sounds good to me....thanks.... :thumbup:
Post by: Brass_Machine on August 25, 2009, 10:11:10 AM
Looks good. I actually have a small (very) tumbler and want a bigger one... this may be my way.
Post by: Jonny on August 26, 2009, 01:20:44 PM
The tumbler looks like a very useful tool i nearly imported a vibro jobby from US two years ago but the right ingredients were hard to come by in UK only could find very small quantities.
Lots of small aluminium machined parts to debur, blend in, and then mirror polish (mop.)
Post by: Bluechip on August 26, 2009, 03:02:05 PM
Jonny
Tried this lot? .. a geezer I know, his wife does lapidary, gets her stuff from here ..
http://www.manchesterminerals.co.uk/
Search for   grit   they appear to do 1kg  & 25kg ..
Not sure if any of the abrasives are suitable for you tho ??
Dave BC
