The Shop => Electronics & IC Programing => Topic started by: geoff_p on January 22, 2015, 05:28:20 AM
Title: Transformer orientation?
Post by: geoff_p on January 22, 2015, 05:28:20 AM
I really want/need/absolutely-must tidy-up my CNC power cables etc.  At present it looks very much like the original definition of PC = 'Proliferation-of-Cables'
I've got a case from an ancient PSU into which my transformer will fit, along with Rectifiers and Capacitors.  The three Axiis-drivers will mount externally, on top, and ...
There's space for the Arduino inside the case.
Will the field from the transformer have any adverse effect on the Arduino?  Should I try to mitigate it by rotating it as per either/or of the attached sketches?
Title: Re: Transformer orientation?
Post by: awemawson on January 22, 2015, 01:46:28 PM
If the transformer is correctly designed and used the external field should be very low. If however it is 'on the edge' the iron core with leak magnetic field.
Post by: geoff_p on January 22, 2015, 05:05:24 PM
That's about what I reckoned but I thought it better to 'play safe' and ask - for once.
Geoff.
