Gallery, Projects and General => Gallery => Topic started by: Edgwick one on July 14, 2015, 01:12:19 AM
Title: My 1930 Edgwick mark one lathe
Post by: Edgwick one on July 14, 2015, 01:12:19 AM
Here she is the 1930 Edgwick serial number D26
Title: Re: My 1930 Edgwick mark one lathe
Post by: mattinker on July 14, 2015, 08:20:52 AM
David ,
your speed change is different to mine and it has a different brass plate!
(http://i917.photobucket.com/albums/ad16/mattinker/Mobile%20Uploads/P1030718_zps97raix9q.jpg) (http://s917.photobucket.com/user/mattinker/media/Mobile%20Uploads/P1030718_zps97raix9q.jpg.html)
Your thread dial is as ilegible as mine!
Post by: AdeV on July 14, 2015, 09:21:44 AM
Early Edgwicks had the clutch lever top-LHS of the headstock (you can see the end of the shaft on your headstock); on later ones they moved it to the bottom RHS (a much more sensible location) using levers & bosses on the back of the lathe.
I believe the gear selectors are actually the same inside; just with a different style boss.
Post by: Edgwick one on July 18, 2015, 05:27:51 AM
Sorry about the picture quality I will try to get some better pictures and bigger to
Post by: Edgwick one on July 18, 2015, 05:37:27 AM
Oil for headstock gearbox someone has suggested using Shell Tellus which is Hydraulic oil.     I would of thought there was a proper oil perhaps a diff oil or gearbox oil would be better
