Gallery, Projects and General => Project Logs => Topic started by: krv3000 on October 25, 2015, 05:23:02 PM
Title: 12 volt air pump
Post by: krv3000 on October 25, 2015, 05:23:02 PM
hi all well this weekends project was to finish of me air pump sum time a go I got one of them 12 volt air pumps witch turned out to be crap then I remembered that I had a beter pump  that came of a car that had air assisted shocks the shocks where us so put normal ones back on but I kept the pump so a bit digging I fawned the pump and a box for it to fit in to sos no pic of that bit so this weekend I finish it off I made a divider up to separate the pump from the back of the box  then I fitted a handle no idea wear  the handle came from then cut out the hole for the switch then weird it up then glued and riveted the divider in place then marked out the back of the box to cut out drilled 4 holes one at etch corner then cut out with a jig saw then connected the air pipe to the pump then made a mesh grill to cover the  side of the box and I fitted 4 rubber feet  all dun right pics
