Gallery, Projects and General => Project Logs => Topic started by: NormanV on May 05, 2018, 08:58:12 AM
Title: Lathe build project
Post by: NormanV on May 05, 2018, 08:58:12 AM
I decided that I needed a small lathe to make small parts as my Loughborough lathe has a slow top speed. I was thinking of something around 50mm centre height. Then on my daily scan through Ebay I came across an Emco Compact 5 lathe, just the bed, headstock, spindle and leadscrew at a good price, I offered 2/3rds their price and they accepted.
I already had in my possession an unidentified piece of equipment, hardly any use, that had two slides that could be modified to suit.
Title: Re: Lathe build project
Post by: NormanV on May 05, 2018, 09:03:21 AM
I modified the two slides and made them to fit giving me 90mm feed on the cross slide and 70mm on the topslide. I haven't any photos yet as it is apart for another machining process.
The next was to cast an aluminium tailstock that mounts on a steel sub-base. Hole through the centre if roughly drilled, undersize, for machining in situ to achieve alignment.
Post by: NormanV on May 05, 2018, 09:05:44 AM
To machine the tailstock bore I made a temporary tailstock and a between centres boring bar. This bar is a bit on the thin size but it had to be that size to fit through the bore.
Post by: NormanV on May 05, 2018, 09:11:11 AM
The motor that I shall be using is a 180volt 1/2HP DC motor that I have with a speed controller. Thus doing away with the necessity of shifting belts to change speed. (I have already used one of these motors and controllers on my milling machine and I know that it will be good.)
I am using poly V belts for the drive as they run quietly without slipping.
I have fitted new bearings to the spindle and I used one of the old ones to make an idler pulley to tension the belt.
Post by: NormanV on May 05, 2018, 09:14:27 AM
As I have not yet wired up the motor and wanted to get on with boring the tailstock I made a handle to fit the spindle bore expecting it to take a long time but it has not been too bad. I have just taken a rest after approx. 45 minutes work. I am on the final cut with just a spring cut to go.
Post by: NormanV on May 05, 2018, 02:27:15 PM
Here is the lathe saddle showing the cross slide and top slide. The top slide can be swivelled for turning tapers. It is not terribly convenient to do as I have to retract the topslide half way to expose the central locking screw but it did enable me to keep the size down.
Also due to the design of the slides the handles move with the slide which accounts for the long overhang of the cross slide handle. It won't affect the use but it does stick out a bit.
Post by: vtsteam on May 05, 2018, 10:05:23 PM
Good work Norman!! :thumbup: :beer:
Post by: NormanV on May 06, 2018, 03:22:22 AM
Thanks Steve. :beer:
Post by: krv3000 on May 06, 2018, 04:15:11 PM
its getting there brill work
Post by: NormanV on May 07, 2018, 04:47:37 AM
Thanks Bob.
Yesterday I made the tailstock ram. The only material that I had was a piece of 1 1/2" Dia steel. This had to be turned down to 25.7mm (that was what the tailstock bore turned out at) and drilled right through. It weighed less than a third of the original weight by the time I had finished.
I drilled it first and then mounted it between centres to turn the outside. I was delighted to find that over its 220mm length I could not measure any variation in the diameter! It slides silkily smooth in the tailstock.
Today I am going to bore the front end MT2, that should be fun.
Just in case anyone wonders why I have made it so long, I intend having a lever operated tailstock as I understand that it gives a more delicate feel when using small drills. Is that others experience?
Post by: kayzed1 on May 07, 2018, 03:45:40 PM
I have in a plastic bag under the S7 the old  tailstock ram if you want it..Dad must have changed it some years ago...looks ok to my duff eyes.
Lyn.
Post by: NormanV on May 13, 2018, 05:52:26 AM
Kayzed1  PM sent.
Latest job was to make the box to contain the speed controller. I don't have any equipment for sheet metal work so I used my angle grinder to cut out the 2mm sheet aluminium and to score grooves for bending. It turned out very well for me, even the lid fits!
There is enough room for the circuit board the on/off switch and the speed control knob, it should look quite smart.
Post by: John Rudd on May 13, 2018, 05:59:57 AM
Speed control board looks like one of those Chinese jobs from ebay?
Post by: NormanV on May 13, 2018, 06:57:53 AM
It's one of two that I got from you. The other is working very nicely on my milling machine with an identical motor.
Post by: John Rudd on May 13, 2018, 08:39:22 AM
Ahh.....I see..Very good, carry on then... :lol:
Post by: vtsteam on May 13, 2018, 09:06:17 AM
Coming along Norman!  :coffee:
Post by: NormanV on May 14, 2018, 02:39:30 PM
Whilst my main lathe is out of action I have been working in wood. This little lathe is very small and this would mean that I would have to bend over to use it. I decided to make a chest of drawers to raise it up to a comfortable working height and to provide storage.
I was lucky to be given some 20mm plywood so I made the carcase and two drawers. The other four drawers were a problem as the plywood had run out and I didn't want to buy more when scrounging would do. I managed to acquire a panel from some sort of industrial boiler that was made from 2mm aluminium. I used this to make the sides and bottom of the drawers, I had already made the fronts and backs of the drawers from the plywood.
I have ended up with a very heavy and very sturdy stand for the lathe at no cost.  It is not beautiful but it does the job!
Post by: vtsteam on May 14, 2018, 09:17:42 PM
That was fast!  :clap:
Post by: NormanV on May 15, 2018, 01:00:36 PM
Yes Steve, it was fast but not very accurate, but good enough! I am good at that sort of thing.
I am thinking ahead. Screw cutting, I had originally thought that it would be good to build an electronically controlled leadscrew. Then I realised how many complications are brought into that.
My latest idea is to use timing belts and pulleys. I don't want to make an unlimited range of threads. Maybe just a few to start with, .5,.75, 1mm. If there is a need for a special thread later on I can purchase the needed pulleys. I like the idea that it would be very quiet running rather than gears that rattle. Is this a practical approach? Has anybody tried it? Surely it would be accurate enough, it is used for timing camshafts on car engines.
Post by: kayzed1 on May 15, 2018, 02:27:50 PM
Posted today Norman.
Lyn.
Post by: NormanV on May 15, 2018, 03:09:39 PM
Thanks Lyn
Post by: vtsteam on May 15, 2018, 06:02:42 PM
Norman, you probably can do that, but if you think about it you'll likely use the same number of timing pulleys and the same sizes as you would change gears. And it might actually be a larger package overall in size, since gears mesh, while pulleys need to stand apart.
But certainly would be cleaner to change-- which is, I think, a great advantage.
Post by: vtsteam on May 15, 2018, 06:11:55 PM
A threading system I've often thought about for a small lathe is the "master thread" type of spindle attachment.Basically you attach a threaded piece to the pulley end of the spindle, arrange a follower in it. Like an old style gramophone needle. That follower is on a rod that extends out to the carriage, and pushes it along (it is disengaged from the leadscrew). So whatever pitch thread the "master' has is duplicated on the work.
 I think they were used on the Unimat lathes. I've seen a fancier version on a larger lathe, and kept the picture for years -- don't remember where I got it from.....see below.
Post by: Fergus OMore on May 15, 2018, 06:29:46 PM
Ned Westbury described an attachment in one of his small books -Lathe Accessories???
Again, I suspect that Prof Dennis Chaddock did something similar in his Quorn Book
Probably it all came out of from Holzapffel.
So it is not new but certainly interesting. I DID Maudsley and Holzapffel in 1946 as part of my studies which suggests -- ornamental turning too
Regards
N
Post by: vtsteam on May 15, 2018, 09:20:06 PM
Timing Pulley type:
Norman, Knaell made a commercial set of toothed pulley types for the Taig lathe. Doesn't seem to be around any more, but pics of it still can be found and will maybe help you figure out a similar system.
Go here and click on the picture links:
http://www.cartertools.com/minimech.html
Thread Copying Type:
Deciphering the photo above that I attached -- it consists of:
1.) A long steel push rod that passes through a bushing on top of the headstock and one on top of the tailstock.
2.) Brass collar stops on that push rod at headstock and tailstock to limit its movement to the length of the "master screw" when resetting it.
3.) A follower toothed arm that sets in the master screw.
4.) A lathe tool holder attached to the pushrod.
5.) An adjustable vertical steel rod that serves as a rest and support on the topslide. I see a wingnut on the topslidethat retains a smooth plate. The end of the vertical rod slides along that plate with the topslide stationary, I believe. I think this rod sets the depth of cut. Not sure how pressure is applied to the lathe tool, but maybe it's just the weight of the attachment.
That's pretty much it.
Master screws could be made up on another lathe, and in some cases could be made from commercial threaded rod for the larger common sizes.
Post by: PK on May 15, 2018, 11:09:14 PM
Thinking...thinking... That's actually a really clever way to do it.
99% of my thread turning is either 1.25mm/1mm/0.75mm pitch and I always leave the half nuts locked and run backwards.... I could just have three reference screws. It's a lot simpler than a gearbox...
Thanks for the post!
Post by: awemawson on May 16, 2018, 02:33:32 AM
Yes Denis Chaddock described a follower for grinding threads on the shanks of end mills on the Quorn T&C grinder
Post by: Fergus OMore on May 16, 2018, 02:36:56 AM
Fascinating stuff- thank you.
I'm desperately trying to get my aged head around a new U2 Asiatic clone of a Deckel tool and cutter grinder to counter senile dementia.
Kind regards
Norman
Again- thanks Andy. The grey matter isn't as addled as I imagined
N
Post by: NormanV on May 16, 2018, 04:21:48 PM
I've had a boring afternoon. :D
I have been given a tailstock ram for a Myford lathe (thank you so much Kayzed1) that is slightly larger than the one that I was making. Which meant that I had to bore out my tailstock casting to fit. As I am rotating the lathe by hand it took a long time, especially where the split cotter is situated. That took a bit of effort to turn the mandrel as the cotter is steel and the tailstock is aluminium.
Anyway, it is done and I didn't go oversize as I had feared. All I need to do now is to hone the hole to make it a perfect fit.
Here is my boring set up, I've shown it before but this is from the other end and shows my temporary tailstock. I used the saddle to push the tailstock along. Steve, (VTsteam) will recognise the method as it is how Dave Gingery showed to do it to build his lathe.
Post by: vtsteam on May 16, 2018, 08:54:52 PM
You're welcome PK. I can't tell you how many times I've looked at that photograph -- copied off the internet 15 years ago -- I don't remember where. It took a long time to figure out what was what. I'm still tempted to add it to my old Gingery lathe.  :coffee:
But for now, working on the new lathe.  :dremel:
And Norman(s) here's one more possible method for thread cutting without change gears... uh I guess you'd call it the pantograph method:
Slightly more information here:
http://www.jacquesmaurel.com/machining
I found a copy of the referenced Model Engineer (4270, April 2006) on ebay and sent for it. But it will apparently be two weeks or more getting here from UK shores. I'd appreciate it if someone could send me a copy of the article before that. -- though I had worked out and tested an electronic change gear system for my new lathe, I think I would prefer the mechanical simplification of something like this. Plus I think it's really cool.  :dremel:
Norman (Fergus) sounds like a good use of time to me! :beer:
Norman (lathe builder) Yes indeedy, that boring method is familiar -- bored my Gingery headstock and tailstock that way, and will do it again on the new lathe. With the weird reversal that I already have a tailstock bore and will use that to bore the headstock. Either way, they come out the same Z and Y axis position on the ways, parallel and concentric, which is the point!  :ddb:
Post by: NormanV on May 17, 2018, 01:29:27 PM
Thank you for the suggestions. I don't think that it is worth my while making one of the linkages for thread following as my requirements are very rare and I am more interested in fitting it with a fine feed to save me from having to wind the handle all the time. If I have fine feed it is just a step away from thread cutting abilities. The Knaell device is enough information for me, it is practical to do it with timing belts.
I need to do some measuring and sit over a list of timing pulleys to see if I can fit it all in. I also want to incorporate a dog clutch on the end of the leadscrew, this lathe does not have half-nuts to disengage the drive.
Post by: NormanV on May 17, 2018, 02:42:24 PM
I've had a look at it and it appears that I could set up to cut .75, 1, 1.5mm threads and a fine feed of .1mm per rev. This would need six pulleys and four belts and cost just under £50. That doesn't sound too bad.
I will file away the sketches for a later date.
Post by: NormanV on June 08, 2018, 09:20:24 AM
Work has come to a halt on my lathe. I am moving house shortly and will not have a workshop for a few months, but when it is built I will be back to work!
Post by: vtsteam on June 08, 2018, 09:28:06 PM
I know the feeling, Norman. Looking forward to when you resume. :dremel:
Post by: gerritv on June 09, 2018, 07:33:23 AM
There is a simpler threading method using the follower principle: http://cartertools.blogspot.com/2011/01/monty-remons-taig-lathe-mods-part-2.html
This works very well on small lathes. I have used this on both my Unimat and Taig.
Post by: nel2lar on September 18, 2018, 09:09:58 PM
Norman
Been gone for a while trying to catch up. What a beautiful project and you are making the old girl look good. I will be following when you resume. Sorry to hear that you will not have the shop to play in. I do not know what I would do without mine, I guess go insane. Looking for the finally.
Good Job
Nelson
