Gallery, Projects and General => Project Logs => Topic started by: sbwhart on February 09, 2016, 02:43:50 AM
Title: 2-6-0 Mixed Trafic Tender Locomotive
Post by: sbwhart on February 09, 2016, 02:43:50 AM
Its been some while since I started a thread, but I haven't been idle. Since getting my Simplex in Steam and doing a little tidying up work on it I've been pondering what to take on as my next long term project. I have the fancy to doing a larger tender loco, I dropped on a set of Don Young drawing for his 5" Gauge 2-6-0 Horwich Mogul otherwise known as a Crab due to its appearance. Don's drawings are beautifully detailed and have many of the features of the full sized engine, but her I hit a problem, I'm not that bothered about it being an exact scale model as long as it looks ok when its over on the far side of the track I will be happy I'm more interested in its ease of manufacture, and it being a good runner. So I will be using Dons drawings only as a guide, and will be redesigned it extensively to make it easier to make:- her are my objectives and list of constraints for the design.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/loco%20picture_zpsoahmugj5.png) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/loco%20picture_zpsoahmugj5.png.html)
Objectives:-
1:- 5" Gauge Miniature Locomotive
2:- Good Reliable Runner
3:- Extensive use
4:- Haul a minimum of 8 people
5:- Resemble a 2-6-0 Horwich Crab
Constraints:-
1:- All Features to be functional and relevant to use of a Miniature Locomotive
2:- Minimum of cast parts
3:- Make Maximum use of Don Young's design
4:- Maximum Use of laser cut parts
5:- Maximum use of commercially supplied Items (Boiler and Fittings)
6:- Simple Construction
7:- Simple and easy to maintain
8:- Transport by one person
So there we have it:-
Every project has to start some ware so I decided to start with the cylinders as I thought this would be the most difficult part to make and if I couldn't make them there was no point in taking it any further. I didn't wont to use castings I wanted to make them from a billet of cast iron, this called for a redesign of Don Young's drawing. I kept all the main critical for function features:- over all length valve ports cylinder piston valve relationship etc, but reduce the cylinder diameter to 1 3/4" 45mm and simplified other features so that it could be made from billet.
Progress to date:-
Cutting the meehanite cast iron billet to size.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02593_zpsu9f3qrul.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02593_zpsu9f3qrul.jpg.html)
I then roughed it out on the mill and finished square using an angle plate
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02600_zpsycmjyogv.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02600_zpsycmjyogv.jpg.html)
spotted out the cylinder and valve position using the mills DRO and located in large four jaw using a wobble bar.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02605_zpsuxledrmc.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02605_zpsuxledrmc.jpg.html)
Roughed out the bores.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02603_zpsolfnokse.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02603_zpsolfnokse.jpg.html)
And then set up on the cross slide and using a between centre boring bar finished the bore.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02608_zpskdadwgf1.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02608_zpskdadwgf1.jpg.html)
First bore done only another three to go.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02611_zpsmqezqejo.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02611_zpsmqezqejo.jpg.html)
That's as far as I've got.
I'll keep you posted as things progress.
Title: Re: 2-6-0 Mixed Trafic Tender Locomotive
Post by: chipenter on February 09, 2016, 04:05:36 AM
I like your idea the cylinder castings from Reeves are £367.06 , will be watching at 72" long not so small .
Post by: John Rudd on February 09, 2016, 05:02:20 AM
Looks good Stew,  :dremel:
maybe a bit too ambitious for me..... :scratch:
Post by: DavidA on February 09, 2016, 07:29:06 AM
Reminds me I really do need to make progress with my Fowler 4F.
The cylinder (inside twin) will also be hewn from the solid.
Looking forward to seeing more of your project.
Post by: sbwhart on February 09, 2016, 07:32:42 AM
Thanks for looking chaps
I bought all the bar material to make both cylinders including covers, piston, valve sleeves and valve spool for £160 so I recon I've saved myself a nice bit of cash, to be honest I think what they charge for castings is extortionate. On the down side there is quite a bit of machining to get them where I want, but on the plus side the continuous meehanite is lovely to machine, free of blow holes and hard inclusions, and once you have the billet for the cylinders squared up its a lot easier to handle than an odd shaped casting, I won't round the outside up until I have all the rest of the features machined.
I'm just going to take it one part at a time, my first hurdle is the cylinders, its pushing the capacity of my machine, so I'm keeping my fingers crossed.
I'll keep you posted with updates, so watch this space.
Post by: sbwhart on March 21, 2016, 08:15:45 AM
Well I've got the cylinders finished
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02661_zpsbmjesnlo.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02661_zpsbmjesnlo.jpg.html)
And a few process shots
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02651_zps2e9lnf4k.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02651_zps2e9lnf4k.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02648_zpsse53kdz2.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02648_zpsse53kdz2.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02644_zpsgwm4xnqs.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02644_zpsgwm4xnqs.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02642_zps16ommff7.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02642_zps16ommff7.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02640_zpsgnioqc58.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02640_zpsgnioqc58.jpg.html)
Post by: joshagrady on March 22, 2016, 02:14:54 PM
Wow!  That's looking great.  Keep up the good work, and keep the pictures coming.
Just to get a sense of the scale of the project, what is the size of your lathe?
Post by: sbwhart on October 11, 2016, 05:13:37 AM
Well its been a busy summer I've been beavering away on this project as well as running my Simplex Loco I recon I've clocked up about 250 miles on it, any way I thinks I'm well over due for giving you guys an up date, I'll probably spread it over a couple of post as I've made a fair bit of progress.
Valve sleeve
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02676_zpssm3wxhq7.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02676_zpssm3wxhq7.jpg.html)(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02681_zpsmoieelyu.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02681_zpsmoieelyu.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02677_zpsneu1yexj.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02677_zpsneu1yexj.jpg.html)
Spool Valve
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02687_zps2cty8fvw.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02687_zps2cty8fvw.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02704_zpszm577w6p.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02704_zpszm577w6p.jpg.html)
Piston Rings
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02713_zps7qfh31hi.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02713_zps7qfh31hi.jpg.html)
Valve Cover
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02726_zpsznfz7gkw.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02726_zpsznfz7gkw.jpg.html)
Guide bar bracket
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02730_zpshqal8vlk.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02730_zpshqal8vlk.jpg.html)
Family Picture
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02731_zpsophtwqkn.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02731_zpsophtwqkn.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02736_zps5ryzjojh.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02736_zps5ryzjojh.jpg.html)
I've got the frame built and the cylinders mounted I'll show pictures of this in the next instalment.
Post by: DavidA on October 11, 2016, 07:38:55 AM
Stew',
Nice to see you are making progress.
I have just (last night) made a start on machining the wheels for my Fowler 4F. I must post some pictures and bring the thread up to date.
Must remember to charge the camera batteries this time.
Post by: krv3000 on October 11, 2016, 04:18:49 PM
work well dun
Post by: sbwhart on October 12, 2016, 02:16:01 PM
Thanks for your comments chaps
Her's a few more in process shot build:-
The horn blocks were made from the off cuts of the cylinders
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02737_zpsvramuj5z.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02737_zpsvramuj5z.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02738_zps2aqnm3xz.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02738_zps2aqnm3xz.jpg.html)
The frames were Laser cut the horns were screwed in place and the frames bolted back to back and the horns milled out so that everything lines up
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02743_zpsvuruaq6n.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02743_zpsvuruaq6n.jpg.html)
The horizontal streachers were just 3/8" black plate the vertical streachers were laser cut fabrications silver soldered together.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02745_zpsg8de1chg.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02745_zpsg8de1chg.jpg.html)
Drag Beam was also a LASER cut fabrication silver soldered together.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02749_zps6hnnogzl.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02749_zps6hnnogzl.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02750_zpsivosbqjt.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02750_zpsivosbqjt.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02751_zpskpjdb7hp.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02751_zpskpjdb7hp.jpg.html)
Hers a few shots of the assembly so far
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02754_zpsznecnpec.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02754_zpsznecnpec.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02755_zpsdduf9m6d.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02755_zpsdduf9m6d.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02756_zpsqq5yrush.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02756_zpsqq5yrush.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02757_zpsevlv1c7p.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02757_zpsevlv1c7p.jpg.html)
I've now made a start on the wheels axles and axle boxes I'll up date you when they are done.
Post by: Will_D on October 12, 2016, 04:23:10 PM
Who on earth makes a 7" rule?
Seriously, great progress.
Laser cut frames? Ye youngsters have it so easy in my day it was a hacksaw and files!
Post by: tom osselton on October 12, 2016, 05:02:51 PM
And so it starts........
You were lucky to have a hacksaw!  :D
Nice build says the lurker!
Post by: Stilldrillin on October 12, 2016, 05:27:29 PM
Those assembly pics show you've come a long way, already.
Nicely done Stew!  :thumbup:
Post by: sbwhart on October 13, 2016, 01:37:51 AM
RDG they give them away when  you make a purchase they have there Tel No and web address on the back along with the moto "A little bit extra with RDG"
Hacksaws and files you were lucky to have them it was flint when I started.
 :lol: :lol: :lol: :lol:
Thanks for your input chaps
Post by: DavidA on October 13, 2016, 07:27:21 AM
 A quick aside re rules (scales to our American and European colleagues).
Some time back at work I was having problems getting some 'rule size' cutting jobs the right length.
It turned out that one of the staff had clipped the end of the rule while measuring a job in the bandsaw.
So he ground off 1/8" from the damaged end. And didn't tell anyone.
Post by: raynerd on October 13, 2016, 01:00:40 PM
Stu, cracking build.
Can I ask your process for profiling the cylinders - they look lovely, I can`t believe you have profiled them from the billet!
Post by: sbwhart on October 13, 2016, 02:29:54 PM
Hi Cris
The radius profile is just for appearance the cylinders will function just as well if they were left square. So all I did was to mark the radius on the end face and roughed them out with a series of flats with an end mill then blended them in with a file they didn't need any more than that.
Post by: raynerd on October 13, 2016, 02:43:02 PM
Cheers Stu, fully understood it was appearance only but they look lovely. So they were hand filed. Jeeez.... I need to practice more!! Excellent work (but as I`ve said for many years, sod the engines and build a clock!  :wave: :) - you`d make a bloody brilliant clock )
I look forward for the next instalment.
Post by: Auskart on October 13, 2016, 11:25:48 PM
Nice work  :clap:
Post by: millwright on October 14, 2016, 04:40:25 PM
Nice job Stew looking forward to more on this build.
Post by: sbwhart on October 28, 2016, 02:46:58 AM
Thanks for your interest
I,ve just completed machining the wheels: I was given a set of casting by a friend, some one had made a start of machining them the outside face had been machined up and the hole for the axle had been machined, some had the back face cleaned up, and all had the back hub face machined, but the hole was too big and the hub face was to thin meaning the rim of the wheel would rub on the frame. A set of unmachined casting will set you back about £200 so it is well worth the effort to recover them.
First job was to fit a bush with a flange to the bores fixed in place with high strength loctite and a small grub screw fitted down the joint.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02765_zpsce7c6bjz.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02765_zpsce7c6bjz.jpg.html)
That should keep it in place.
Next job was to set the wheel up in my four jaw chuck clock the dia of the bush up true and tap the back face of the wheel up against the face of the chuck, to do this I had to put some packing on the jaws in the shape of some small button magnets.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02760_zpsjwxvxhf6.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02760_zpsjwxvxhf6.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02759_zpsypgvprih.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02759_zpsypgvprih.jpg.html)
With a boring bar to get every thing running true rouch the bore out and finish off to size with a reamer
Face up the new hub to give the correct stand out, face the rim to the correct thickness and turn the dia for the flange to size.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02763_zpsczz5lyof.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02763_zpsczz5lyof.jpg.html)
I have a 300mm old fasion  vernier to measure the rim, the price was right and it does the job
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02761_zpshuy6keo3.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02761_zpshuy6keo3.jpg.html)
To machine up the front face I used my home made face plate that I made a few uears ago from a disc of steel donated by bluechip, so that I could clamp down on the rim I used two way tape to stick four washers to the plate and I screwed a mandrell into the centre.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02766_zps0cof17pb.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02766_zps0cof17pb.jpg.html)
Turned the mandrell up for a nice push fit on the bore.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02767_zpszphzbe1e.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02767_zpszphzbe1e.jpg.html)
Rough out the out the wheel tred dia and flange thickness
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02768_zpsg3lainpk.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02768_zpsg3lainpk.jpg.html)
With a radius tool finish off the dia and flange thickness
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02772_zpsllthycxu.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02772_zpsllthycxu.jpg.html)
Using the same mandrell as for the face place mount it on the mill and clock the mill up on it zero the DRO and move the off set for the the crank pin and lock the table up.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02774_zpskhwhth54.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02774_zpskhwhth54.jpg.html)
Drill and ream for the crank pin:- its important that the off set is exactly the same for each wheel so once you've done one don't move any thing.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02775_zpslukgnpbk.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02775_zpslukgnpbk.jpg.html)
Thats it all done
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02776_zps6yp9ldqp.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02776_zps6yp9ldqp.jpg.html)
That saved me £ 200
 :D :D :D :D
Post by: DavidA on October 28, 2016, 06:47:04 AM
Nice wheels,
My procedure for machining the wheels for my 0-6-0 was very similar. The main difference was that I built a jig to hold them and clamped it on the faceplate.
Mine are really only temporary as they don't have the required number of spokes.
Good job; keep it going.
Post by: sbwhart on March 08, 2017, 03:37:43 AM
Thanks for your interest Dave you were the only one to reply so I guess your the only one watching.
Any way
Hi Chaps:- if any one does read it.
I've not updated this thread for a while I did get distracted with a couple of other projects and I was a bit put off from updating it because of the problems I was having with photobucket, but now that I've gone add free its making the process far easier.
I have done some work on it and I'm planning too have a intense period of activity on it.
So her's the update
The main driving axles are made fro 3/4" ground mild steel bar, the first job was rough cut them to length.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02779_zpsldkntfry.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02779_zpsldkntfry.jpg.html)
Face them all off so that they were all exactly the same length.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02782_zpsicqzhxbd.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02782_zpsicqzhxbd.jpg.html)
Using a collett centre drill.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02783_zpskngayc5s.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02783_zpskngayc5s.jpg.html)
Then between centres turn down the end for a nice close fit in the wheels
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02786_zpssobpuvw4.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02786_zpssobpuvw4.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02787_zpst4b4acax.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02787_zpst4b4acax.jpg.html)
I then drill down the ends and cross drilled oiling way this way to oil the bearing all I have to do is squirt oil down the centre of the axle. sorry no pictures of this.
Next turn up and fit the driving pins for the wheels and loctite them in the wheels
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02792_zpswjy9jiuf.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02792_zpswjy9jiuf.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02797_zpsuybifpzd.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02797_zpsuybifpzd.jpg.html)
Axle boxes Made from a chunk of cast iron
1st job square the chunk up to size
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02799_zpsjk6w2r2c.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02799_zpsjk6w2r2c.jpg.html)
Cut each axle box off from the chunk
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02801_zpsyp1ixeri.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02801_zpsyp1ixeri.jpg.html)
In the four jaw face off to length.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02802_zpsxrqbf8w3.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02802_zpsxrqbf8w3.jpg.html)
Then in the mill I found the centre of each box and put in a centre drill, and using a woble bar centred the box back up in the four jaw and drill out and reamed 3/4"
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02803_zpsp2o58ywj.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02803_zpsp2o58ywj.jpg.html)
Then turned up  3/4" mandrell
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02805_zpseswdmvmc.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02805_zpseswdmvmc.jpg.html)
Transferred  the chuck over onto the spin indexer and milled the groove for a nice slide fit on the frame hornblocks this way every thing will be concentric keeping the axle boxes in line.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02807_zps0ytt9tkw.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02807_zps0ytt9tkw.jpg.html)
Radius off the groove this is so the axles will roll on the track curve and humps and bumps.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02808_zpss1tzwfek.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02808_zpss1tzwfek.jpg.html)
This is the axles and axle boxes assembled with the springs.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02813_zpsvexlh6fs.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02813_zpsvexlh6fs.jpg.html)
Then using a quartering jig assemble the wheels:- its important for the wheel coupling that each set of wheels are quartered exactly the same
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02814_zpsmzx2wmaa.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02814_zpsmzx2wmaa.jpg.html)
I post a picture of the wheels in the frame at a later dat.
I'm currently building the pony truck this is being fabricated from laser cut parts.
Post by: AdeV on March 08, 2017, 01:16:54 PM
Hi Stew,
David's not the only one watching..... I just don't often comment (probably should really).
It's a great looking build so far, surprisingly complicated things, these steam engines! Are you making your own boiler, or getting a commercial one? Oh, and nice fix on those wheels BTW. You make it look and sound so simple, I'd be swearing and cursing after the 2nd one I bet.
Looking forward to the next installment!
Post by: awemawson on March 08, 2017, 02:01:56 PM
Hi Stew -
yes I'm here watching as well, though not a model steam train sort of person, so not a lot to contribute, despite being Chairman of SM&EE once upon a time :med:
Post by: Spurry on March 08, 2017, 02:31:23 PM
I too, like to watch these sorts of things in progress. The main problem is that if one clicks 'notify' then all the people who comment nice job etc, get 'notified' too. Those sorts of messages, I feel, detract from the main thread of interest. Personally I try and wait until the end before commenting. But the hapless contributor thinks they be being ignored, but I would hazard a guess that is not usually the case.
Now if there was a Like button or similar that did not interfere with the thread as such...if only...
There, I have gone a broke my own 'rule' now.
Post by: tom osselton on March 08, 2017, 03:03:19 PM
Another lurker here watching!
Post by: Stilldrillin on March 08, 2017, 03:56:45 PM
I've been rather quiet recently, Stew.
Lurking. Appreciating. Learning......  :thumbup:
Post by: jb3cx on March 08, 2017, 05:05:38 PM
I am also watching,it will be a fantastic loco when finished,  What you have accomplished in a few months is brilliant. 20 years ago I started to build a 7 1/4  Holmside.at the moment just setting the valves ,mind you I only work on it about 2 hours a week .
Peter w
Post by: xo18thfa on March 08, 2017, 09:55:09 PM
Nice work.  So the hornblocks are square pieces, rather then the usual ribbed castings.  Especially like the way you did the cylinders. Great picture lesson
vr Bob
Post by: edward on March 09, 2017, 04:38:55 AM
I'm reading, but I only like to contribute if i have something useful to say, which isn't that often!
Although while I am here, could you give an idea of what the arrangement of your lathe is? it looks like you've some kind of gearbox in front of the actual headstock?
Post by: sbwhart on March 09, 2017, 05:15:06 AM
Thanks for you're interest and replies Gents, I must admit that I'm more of a lurker than a comentre these day, but it is nice just to have a few comments just to reminder that people are looking.
To answer a few ?
No I'm getting a boiler made by Western Steam it shoul be ready this September.
vr Bob
Yes the hornblocks they are square, made from the off cut material from the cylinders, waste not want not, but there is nothing new about having them way LBSC used this method from time to time.
The lathe is a Chester Model B a 3 in 1 with the mill drill head removed, cheep and nasty but its done everything I want in the last 8 years, its got a huge swing which is very useful at times. It doesn't have a gear box as such, the speed is changed with a belts and pulleys.
Hi Dave:- hope all is well with you and your's
Thanks again for your comments
Post by: edward on March 09, 2017, 06:01:54 AM
Ah, that explains the headstock arrangement - it was the lever on the front behind the chuck that threw me.
You do some very fine work on it for a 'cheap and nasty' machine - just goes to show its the craftsman not the tool that makes the job :)
Post by: DMIOM on March 09, 2017, 03:21:15 PM
..... just goes to show its the craftsman not the tool that makes the job :)
Well said Edward!
Dave (another lurker with nothing to contribute re loco but lots of admiration for those who do)
Post by: DavidA on March 10, 2017, 08:54:49 AM
 Stew',
Just a comment.   There has been a crab running on the Keighley and Worth Valley Railway for the past few days. In the same livery.  And a very impressive loco it is.  I do remember these from my days as a trainspotter, long before the word was a derogatory term.
Yesterday, as I was driving through town there was a wide load procession of low loaders and police escort vehicles heading towards Howarth.  So I am assuming the loco has moved on.
By the way, where did you get the wheel castings from ?
Post by: DavidA on March 10, 2017, 11:56:53 AM
Reading through I see how you obtained the wheels.  Sorry about that.
Post by: xo18thfa on March 29, 2017, 07:33:15 PM
Nice work.  Picking up some handy tips.  The cylinders are gorgeous.  I'm following your technique (when the time comes)
Thanks, Bob
Post by: sbwhart on May 19, 2017, 11:02:58 AM
Time for another update:-
Things gave moved on a pass. the frame is assembled and the wheels are in and the pony truck is completed and in the frame, I'm taking her to the track next week to push her round the bends to check that the pony truck works.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02931_zpsmf4ugolv.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02931_zpsmf4ugolv.jpg.html)
And a few in-process shot of the pony truck made from laser cut parts silver soldered together.
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02915_zps5ehxmnvm.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02915_zps5ehxmnvm.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02921_zpsdnblsb2z.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02921_zpsdnblsb2z.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02926_zpssnz6xw6z.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02926_zpssnz6xw6z.jpg.html)
The centralising spring
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02925_zpsfrykbzob.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02925_zpsfrykbzob.jpg.html)
(http://i431.photobucket.com/albums/qq32/sbwhart/Horwich%20Crab/DSC02933_zpsiagndu5v.jpg) (http://s431.photobucket.com/user/sbwhart/media/Horwich%20Crab/DSC02933_zpsiagndu5v.jpg.html)
Post by: sbwhart on February 12, 2018, 03:07:36 AM
I think its about time I post an update of progress so far.
I've been slowly beavering away at the build except for a few small tooling projects just as a change. I've got the slide bars and cross head made and I'm making the valve linkage at the moments I did buy a set of laser cut linkages but I didn't like the way you have to fabricate the forked ends so I'm making them out of solid so that they can be case hardened.
The motion plate is made from a laser cut part with the edge fluting milled in the same as for the radius Link Bracket that's shown her clamp roughly in place as a trial fit it won't get fitted till I have the rest of the valve links fitted so that it can be correctly placed.
And I've recently taken delivery taken delivery of the Boiler from Western Steam and I must say they've made a lovely job of it with great service.
Any way her's a few photos.
(https://i.imgur.com/fgWw5ow.jpg)
(https://i.imgur.com/4x8aoPV.jpg)
(https://i.imgur.com/SmOYlEc.jpg)
(https://i.imgur.com/pyICSU4.jpg)
Post by: chipenter on February 12, 2018, 04:18:11 AM
Good to see slippers on the cross head that will last a lot longer .
Post by: RotarySMP on February 12, 2018, 06:55:41 AM
Lovely workmanship. Thanks for taking along for the ride.
Mark
Post by: millwright on February 12, 2018, 02:55:26 PM
Nice to see this back on track so to speak, had to read it all again to refresh the memory. Errr pics seem rather large Stew  :bugeye:
Post by: DavidA on February 12, 2018, 04:48:47 PM
I also was wondering about the pics.
Do you know what this loco is going to weigh when it is finished ?
Post by: sbwhart on February 13, 2018, 12:51:41 AM
Thanks for your interest Chaps,
Sorry about the pics, one reason I haven't posted earlier is that I got really brassed off with photobucket since they've been run by a bunch of greedy managers so I stopped taking pictures, I've since decided to try another hosting provider (imgur) and i'm only just getting to grips with there system, they posted fine on the Model Engine Maker forum but for some unknown reason they cam out large on this forum.
Sorry Dave I have no idea but I think it will be more than a one man lift, as I struggle to lift the boiler on its own.
Post by: DavidA on February 13, 2018, 09:12:01 PM
 Stew,
I post picture directly from my computer. No need to use photobucket etc.
Post by: melgump on February 14, 2018, 12:37:01 PM
I right click on the picture and then choose " show image ". Picture is then monitor size.
Cheers,
Ray.
Post by: Spurry on February 14, 2018, 02:08:46 PM
Didn't work for me, but a left click on picture then Control with a minus(-) sign did. Then Control with  a plus (+) sign, to revert to submitted size.
Post by: awemawson on February 14, 2018, 02:23:17 PM
it's very much browser dependent.
That's why posting at 800x600 is a good choice
Post by: Doc on February 14, 2018, 03:53:20 PM
Hey Stew I'm here I too done post comments as often as I should.
   I suspect I'm not the only one my current little build and I mean little compared to this has gone from start to finish with very few comments. So at least I hope someone got something out of my posts.
  Anyway your build has been awesome so don't stop keeping us updated. You have totally amazed me. I would love to be able too do a build like this but I would not know where to start!!
Post by: philf on February 14, 2018, 06:31:14 PM
Doc, Stew,
I too am guilty of not posting many comments - it doesn't mean to say I'm not interested or appreciative of your posts - I really enjoy them. Doc - you amaze me with your productivity - goodness knows how many projects you'll complete when you're retired. If I thought I could offer any constructive comments I would but you obviously know what you're doing and I can't add anything.
My thanks go out to all the MadModders who contribute.
Cheers.
Post by: sbwhart on February 15, 2018, 03:31:19 AM
I've worked out why the image is so large
These are a better size
(https://i.imgur.com/pyICSU4l.jpg)
(https://i.imgur.com/SmOYlEcl.jpg)
(https://i.imgur.com/4x8aoPVl.jpg)
(https://i.imgur.com/fgWw5owl.jpg)
Post by: awemawson on February 15, 2018, 04:35:26 AM
 :thumbup:
Post by: sbwhart on February 27, 2018, 02:45:07 AM
Just to give you some idea of the work involved in making the valve linkage.
This is the radius link
Square up a length of mild steel, and drill the holes and corner position and then chew out the material not wanted
(https://i.imgur.com/kxzMs7nl.jpg)
(https://i.imgur.com/NCqJtOul.jpg)
And these are the finished links you can see where they go on the full size picture
(https://i.imgur.com/Aj8cp0el.jpg)
Post by: kayzed1 on February 27, 2018, 01:46:05 PM
Very nice Sir, very nice indeed.
Lyn.
Post by: sbwhart on November 02, 2018, 02:38:53 PM
I've just achieved a significant milestone with this build in that I've just got it running on air
  :D
Its runs a little lumpy because I only roughly centred the valves by eye and I had left some of the brackets lose so things should get better . I've still got to make the radius link to complete all the motion works but I'm very pleased that I've reached this important milestone.
 :ddb:
Post by: Will_D on November 02, 2018, 05:58:36 PM
Well done, its great to see movement after a long time of metal bashing.
It was very satisfying to see my Rob Roy 0-6-0 chassis running on air in 1990. Unfortunately its still packed away from when I moved to Ireland in '91
One day!!
At least I have a access to as few hectares of rugby club for the track!!
Post by: tom osselton on November 03, 2018, 04:56:47 PM
Itís nice to see it running!
Post by: Stilldrillin on November 08, 2018, 05:01:48 PM
It's alive!
Well done, Stew.....  :clap:
Post by: sbwhart on May 21, 2020, 02:45:38 AM
Well I guess its about time I updated you on the progress of this project I'm sorry I've been a bit lacks in posting but I've had a few health issues:- I was diagnosed with prostrate cancer 12 months ago they told me it was curable, its was found by chance as I had no obvious symptoms, we had a friend diagnosed with it, and my wife persuaded me to attend a walk in screening session held locally just to get checked out. I was devastated by the news it really knocked me back. Needless to say our NHS has been absolutely fantastic and before long i found myself on hormone treatment, and I elected to be treated with Radio therapy that I completed at the end of February. I got over this treatment well and now have to wait 6 months for thing to settle down before testing to see how effective the treatment was so I'm keeping my fingers crosses, in the meantime I,m staying positive.
Any way to the project update, once I'd tested the running gear on air I then got stuck in on the tender and completed it last December this is it:-
(https://i.imgur.com/yQsEpyYl.jpg)
(https://i.imgur.com/gcJEUhhl.jpg)
And this is the progress with the Loco I've completed and fitted the smoke box smoke box door and chimney
(https://i.imgur.com/3U5z0xml.jpg)
  I hope you can see the images I'm a little rusty posting
Post by: woodguy on May 21, 2020, 05:12:30 PM
Brilliant Stew!  Lovely job.
Post by: Stilldrillin on May 21, 2020, 05:30:45 PM
Stew.
 The loco is now looking more complete, with the added length of the smokebox assembly.
The tender looks great too, in it's black, lined livery. Well done!
So sorry to hear of your prostate problems.
A couple of years ago, I was grateful to hear. "Well..... It's not cancer".... As he had his camera inserted in my microbore plumbing system.
He prescribed, finasteride.
 My prostate took almost 6 weeks to self destruct, to normal size.
Normal plumbing procedures resumed after around 6 months.
 After 18 months, I'd gained a stone in weight. And a head of new fine hair......
Thinking of you. Hoping all continues to go well.....  :thumbup:
Post by: sbwhart on May 22, 2020, 01:21:03 AM
Thanks Woodguy
Thanks Dave nice to here from you hope your all keeping well and coping with the lock-down. To be honest I'm quite enjoying the shop time and staying at home, the worst part is missing the family especially the grand kids.
My diagnosis was a real shock to me I'd always enjoyed good robust health it really hit my confidence and my levels of anxiety shot up, I'm far more positive now, just need to get over the next 6 months and my first post treatment tests in September.
As for gaining hair the hormone treatment has made my hair line recede even more you would not have thought that possible for a bald old bugger like me.   :D
Post by: chipenter on May 22, 2020, 02:52:43 AM
The follow up is really good the prostate nurses know there stuff , I had mine removed 3 years ago got the all clear in March , blood test once a year for the rest of my life , they don't forget you , glad to see another survivor keep your chin up .
