Gallery, Projects and General => Project Logs => Topic started by: Doc on July 05, 2017, 09:08:21 AM
Title: Radiator build
Post by: Doc on July 05, 2017, 09:08:21 AM
Here is my radiator build for my Little Demon V8. This is the first one I have done I did attempt and failed miserably to build the one in the plans so I made up my own. Here is a short video showing it so far it has to be cleaned up and finished yet.
Title: Re: Radiator build
Post by: Doc on July 07, 2017, 03:17:41 PM
Well I cut one side flashing and am going to try and make the radius on the tanks smaller to blend more withe the side. Anyway here is a short video taking a peak at what its looking like.
Post by: Doc on July 15, 2017, 10:14:35 AM
Latest update plus started 2nd one.
Post by: Doc on July 22, 2017, 08:06:53 PM
Another radiator update.
Post by: Doc on August 13, 2017, 09:32:31 PM
Was going t post an update video with the soldering of the 2nd radiator but unfortunately my video card went bad. I videoed the soldering and when I went to pull the vid off camera I got a file corrupt I tried taking the card and putting it in a card reader and got the same. Dam it anyway. So I need t get a new card.
I do have question has anyone tried these tach meters I am thinking of putting one on but kind of curious as how went they work (or don't)
Here is a link to what I'm talking about.
Blue LED Tachometer RPM Speed Meter (http://www.ebay.com/itm/New-Blue-LED-Tachometer-RPM-Speed-Meter-Hall-Proximity-Switch-Sensor-NPN/261421442448?_trkparms=aid%3D777001%26algo%3DDISCO.FEED%26ao%3D1%26asc%3D20160801204525%26meid%3D95d979d7fb934d168d84a0757d9a128d%26pid%3D100651%26rk%3D1%26rkt%3D1%26&_trksid=p2481888.c100651.m4497&_trkparms=pageci%253Aac8bbd8a-808e-11e7-92da-74dbd180adaf%257Cparentrq%253Ade536e0c15d0abc654917aa7fff9de20%257Ciid%253A1)
Post by: chipenter on August 14, 2017, 03:45:32 AM
I have one on my lathe as its a varible speed  , works well up 2000 rpm , been working for two years .
Post by: Doc on October 05, 2017, 09:05:57 AM
The RPM gauge seemed to respond slow so I didn't use it. I did finish up the rad's and mounting box and gave them a little run.
[ Invalid YouTube link ]
Post by: eskoilola on October 05, 2017, 09:35:52 AM
It is a hall sensor so it reacts on a magnetic field. Obviously the pill supplied is not to be swallowed but glued someplace where the sensor can sense it.
So, I assume, the pill is glued on a rotating surface and the sensor attached nearby.
Basically hall sensors can detect frequencies high enough for this kind of use. The sure can do 1000Hz -> 60000 Rpm.
The electronic involved is very simple frequency counter.
These work. They will flicker on low rpm:s but stabilize as the rpms get higher.
