Author Topic: Coke Forge Build  (Read 106686 times)
Re: Coke Forge Build
« Reply #100 on: April 26, 2015, 03:36:26 PM »
....and it's that last bit I'm USELESS at    :lol:
    • www. sredmond.com
« Reply #101 on: April 26, 2015, 06:17:31 PM »
I'd call tha a pretty steady hand!  :clap: :clap: :bow:
www.sredmond.com
Offline NeoTech
    • Roughedge Hobbyworks
« Reply #102 on: April 27, 2015, 09:16:59 AM »
When "Free hand" becomes.. cheating.  :poke:
« Reply #103 on: May 03, 2015, 12:20:38 PM »
Cheers Lads  :beer:
A bit more done today     :)  , worked on the air control valve spindle , this was turned and screw cut , then slapped onto the mill like so .
Two flats mill on the screwed section .
Then a section of spindle was milled away for the gate /butterfly .
And then a couple of hole were poked in .
Next a 1 mill thick disc was turned , this needs two slots milled . I used an old bearing race to centre the chuck with the aid of my Zero set indicator (Wilson copy) , just love that tool . :dremel:
Then the disc mounted and milled .
Nearly there .
Rob   :coffee:
« Reply #104 on: May 03, 2015, 12:44:57 PM »
hi rob as per brill work
« Reply #105 on: May 03, 2015, 01:11:54 PM »
Top class Rob as usual :drool: :drool: :drool: :drool:
Are you going to "aerofoil" the butterfly like we used to on the racing SU carbs  :doh: :doh: :doh:
« Reply #106 on: May 03, 2015, 01:57:34 PM »
Cheers Bob  :beer:
 :lol: :lol: :lol: I have the David Vizard book out John  :lol: :lol: :lol:
    • www. sredmond.com
« Reply #107 on: May 03, 2015, 08:42:40 PM »
The sculptor is back at it!  :bow: :bow: :thumbup: :clap:
www.sredmond.com
« Reply #108 on: May 04, 2015, 03:32:56 AM »
Looking good Rob, its got to be close to getting fired up now  :thumbup: :drool:
cheers Mick
Offline Zadig
« Reply #109 on: May 04, 2015, 03:45:51 AM »
Very nice Rob, you are a master of your art.
Nice looking mill too.
« Reply #110 on: May 04, 2015, 03:54:14 AM »
Thanks Lads  :beer:
Getting close Mick ,,,,,,,,,,,,,,,,,just need to get me finger out and stop pissing about with other distractions in the shop  :palm:
Aye its not bad  (Aciera F3)  ,,,,,,,,,,,,,,,,,, BUT! not as nice as your pair of mills , Deckel's I believe  :drool:
Offline Zadig
« Reply #111 on: May 04, 2015, 06:09:43 AM »
Just seen the reference to David Vizard, that's a name from the past. I think his how to modify your Mini book is still the most thumbed and dilapidated book I have on the shelf.
I've had a couple of Thiels and a polish copy that was nice - all sold on. The two mills I have now and have done for a few years are an Ajax and a Shizuoka CNC. I got tired of having to buy two lots of tooling for both mills, so when the nearly new and well tooled Ajax came about, I decided to take the plunge.
« Reply #112 on: May 04, 2015, 09:58:44 AM »
Aye Vizard's book is a must for A series engine tuning  :dremel:
« Reply #113 on: May 04, 2015, 10:07:46 AM »
A wee bit more progress this morning , thought I would post now as I need to stop for a curry . :)
Made up a couple of  shouldered washers , cant be doing with way ward springs LOL.
The slot required a tad of hand fitting at the bench .  :dremel:
And it all goes together like so .
Thats the valve just about done , I have left the other end long and un machined as I am still undecided how I will be controlling the valve.
Next ,welded on the dump flange .
And this is it so far .
Cheers Rob    :beer:
Offline Joe d
« Reply #114 on: May 04, 2015, 11:32:26 AM »
Looking good Rob  :beer: :beer:
Be  ready for that BBQ party soon!
Cheers,  Joe
    • www. sredmond.com
« Reply #115 on: May 05, 2015, 06:08:57 PM »
Besides the other glamorous stuff I forgot for a minute about the custom vise jaws themselves. Good to see them again!  :bow: :bow: :clap:
www.sredmond.com
Offline Zadig
« Reply #116 on: May 06, 2015, 02:57:04 AM »
"Glamorous" is the pefect word.
Lovely work. It does have the look of being able to carry out "Uranium Enrichment" mind!
« Reply #117 on: May 06, 2015, 02:06:56 PM »
Cheers Lads  :beer:
Thanks Joe  :thumbup:
Aye Steve the vice jaws have had some use now  :med: ,
 "Uranium Enrichment"  , ,,,,,,,,,,,,mmm  just enrichment of my life  Zadig  :lol: :lol: :lol:
Offline ArnieB
« Reply #118 on: May 10, 2015, 07:33:41 AM »
As Zadig and vtstream said "Glamorus " I am in awe.
but sorry I have put a call into the UN, you never know !!!   :lol:
Arnie.
« Reply #119 on: May 10, 2015, 08:44:00 AM »
 :lol: Cheers Arnie  :beer:
Well a tad more done , Knocked up the blower mounting bracket this morning  :dremel:
This just clips over the bottom rail of the stand , the reason is two fold it  allows a degree of float  and once the forge is pushed back into the corner motor/fan accesses
will be difficult , this way I can just lift the motor/fan assembly out if needed.
Motor attached .
And in position .
Just need a bit pipe work welded up to join the blower to the control valve .
Cheers Rob
    • www. sredmond.com
« Reply #120 on: May 10, 2015, 09:29:12 AM »
Rob, really nice simple idea on the removable mount!  :thumbup: :thumbup: :clap:
www.sredmond.com
« Reply #121 on: May 13, 2015, 04:33:57 PM »
Thanks Steve  :beer: I likes simple    :lol:   , I got a wee bit more done tonight ,a tad of  pipe work  :zap:
Loving my new TIG  ,it welds canny . :)
« Reply #122 on: May 13, 2015, 05:12:23 PM »
Nice looking weld Mate
I take it you like the R-Tech
« Reply #123 on: May 13, 2015, 05:18:12 PM »
Aye its canny mate , :thumbup:
 much better with the new touches , I may put the TIG welded in the other shop as I have a 6 meter touch , it will save me having to drown out the fookin cooling fan with hard core house music , tonight I found Motorhead worked well  :lol: :lol: :lol:
« Reply #124 on: May 13, 2015, 05:53:39 PM »
lol
The new ones have "fan on demand" :drool: :drool: :drool:
At least you wont leave it turned on by mistake  :lol: :lol: :lol: :lol: :lol: :lol:
