Author Topic: Dial Gauge Extender, 3D Printed  (Read 8553 times)
« on: June 13, 2016, 04:21:47 PM »
I have had a dial gauge on my Taig mill for years, and always had the intention of machining a block to take a rod that can be used to set the dial gauge mounted at the top of the Z.   Well, I kind of got round to it.  Whilst doing other work I designed what I needed for 3D printing.
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/Taig%20Mill%203D%20Printed%20Parts/Dial20Gauge20setting20tool._zps0kbttb3a.jpgDial Gauge Extender, 3D Printed
The first part printed was the body to hold the rod and take a small alloy draw bar for locking the rod in position.
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/Taig%20Mill%203D%20Printed%20Parts/IMG_0025_zpsn16wu3wy.jpgDial Gauge Extender, 3D Printed
This took about an hour to print, as it was printed at 0.1mm layers. Once the print was done it needed a little cleaning up and the bores reamed to size, for that reason it has the print software set to 3 side walls and 4 solid layer top and bottom.  Next job was making the little ball handle,  this is also a practice run for the printed Quorn handles in the future.
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/Taig%20Mill%203D%20Printed%20Parts/IMG_0023_zpskkxklvtd.jpgDial Gauge Extender, 3D Printed
I'm using the splined perspex inserts, as they work so well for this kind of stuff and they are easy to make.  In my case a tight press fit, but they could also be glued in if a little loose.
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/Taig%20Mill%203D%20Printed%20Parts/IMG_0024_zpsnmb2rfno.jpgDial Gauge Extender, 3D Printed
If my machining had been as good as the printing you wouldn't see any gaps round the splines.  However, I set the indexer by eye and goofed the spline depth to machine in the perspex on the first two.  Still, no one will see them, will they lads  :thumbup:
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/Taig%20Mill%203D%20Printed%20Parts/IMG_0026_zpsudsowxfl.jpgDial Gauge Extender, 3D Printed
Little bit of lathe work to make the drawbar, it hadn't been cross drilled at this stage, as rain was interfering with my 5 second commute from drawing office to workshop.
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/Taig%20Mill%203D%20Printed%20Parts/IMG_0027_zpsb6seigas.jpgDial Gauge Extender, 3D Printed
At last, final assembly and test.  About 1/8th of a turn on the lever releases or locks the bar in place.  I had hoped to make the tee nut for mounting but rain really has stopped play, it's bouncing down here, so calling it a night.
Re: Dial Gauge Extender, 3D Printed
« Reply #1 on: June 13, 2016, 04:29:04 PM »
Nicely done Joules   :clap: :clap: :clap: :clap:
I like the composite lever  :med:
Offline Pete49
« Reply #2 on: June 13, 2016, 11:29:29 PM »
Very clever. Another use for 3D printers in the workshop. PLA I presume?
« Reply #3 on: June 15, 2016, 04:12:39 PM »
 :D  Of course Pete....
Tee nut made for the Taig and fitted the extender, I will have to see if one fastener is enough over time as it didn't need more than a gentle nip to fix in place.  Following pictures show short and long use, really easy to operate and twist the rod for precision adjustment.
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/Taig%20Mill%203D%20Printed%20Parts/IMG_0029_zpsprwwngzo.jpgDial Gauge Extender, 3D Printed
http://i7.photobucket.com/albums/y253/joulesbee/3D%20Prints/Taig%20Mill%203D%20Printed%20Parts/IMG_0030_zpsdfgljoed.jpgDial Gauge Extender, 3D Printed
Cheers Rob, glad you like the composite ball lever.  I was tempted to use Delrin for the insert, but I like being able to see the cutter in the material  :thumbup:
Offline RotarySMP
« Reply #4 on: June 16, 2016, 05:14:43 AM »
Nice job, and I really like the rendering which that software does.
Mark
Mark
« Reply #5 on: June 17, 2016, 02:15:48 AM »
Thanks Mark, that style of rendering is winning me quite a bit of illustration work.
