Author Topic: home made mill  (Read 50155 times)
Re: home made mill
« Reply #75 on: February 06, 2017, 05:48:50 PM »
still a lot to do need a bench for it a bracket making up to bolt the switch to swafe covers D.R.O and so on
Re: home made mill
« Reply #76 on: February 06, 2017, 05:51:00 PM »
Thats nowt to a bloke like you Bob  :thumbup: :thumbup: :clap:
Re: home made mill
« Reply #77 on: February 06, 2017, 05:51:51 PM »
I when is you gowing to get your lath dun lol
Re: home made mill
« Reply #78 on: February 06, 2017, 07:18:53 PM »
I can see me ending up with that lathe
Re: home made mill
« Reply #79 on: February 07, 2017, 02:59:41 AM »
You must have run out of space by now JOHN, down boy  :ddb:
Offline Biggles
Re: home made mill
« Reply #80 on: February 07, 2017, 11:57:23 AM »
You need a Shaper John!  :thumbup:
Re: home made mill
« Reply #81 on: February 07, 2017, 03:24:34 PM »
I would make space for that
Best Colchester Lathe I have ever seen
Re: home made mill
« Reply #82 on: February 08, 2017, 05:01:31 PM »
hi all as promist sum pics
Re: home made mill
« Reply #83 on: February 08, 2017, 05:07:33 PM »
To quote somebody who often posts here ...... Brill    :lol:
Re: home made mill
« Reply #84 on: February 08, 2017, 06:37:31 PM »
lol its the only wored I can spell properly    :lol:
Offline NormanV
  • United Kingdom
Re: home made mill
« Reply #85 on: February 08, 2017, 07:24:38 PM »
 :thumbup:
Re: home made mill
« Reply #86 on: February 08, 2017, 09:34:10 PM »
 :thumbup:
Offline Fredbare
  • Fakenham, Norfolk
Re: home made mill
« Reply #87 on: February 09, 2017, 10:41:28 AM »
Well done Bob
Re: home made mill
« Reply #88 on: February 15, 2017, 06:32:02 PM »
 :thumbup:
Re: home made mill
« Reply #89 on: February 16, 2017, 04:43:05 PM »
hi all will throw this out there on the mane shaft that's the silver one in the pick on the top there shod be  a ejector nut its a 16mm by 1 mm pitch thread with a hole in it witch you un do the draw bar when the draw bar  hits this it shoves the morce taper free has any one got one they can do a drawing off so I can make one up the manufacture name plat sits right behind the shaft and was well beaten up as people had bin hitting the draw bar with a hammer and the plate at the same time I have removed the name plat as the motor is gnaw 240 volt still kept the plate im going to put a pace of stanles steel in its place hopefully this week end
Re: home made mill
« Reply #90 on: February 16, 2017, 05:03:12 PM »
Iff you have a corser thead on the draw bar it will pull the taper in and then release by unsrewing , turn the chuck or cutter in untill friction is felt tighten the nut a turn or two , jobs a goodun .
Offline Henning
  • Country: no
  • All the kit and no clue!
Re: home made mill
« Reply #91 on: February 17, 2017, 03:24:26 AM »
I do have one of those "undo"- caps on my Emco FB2 mill. All it really is, is a sleeve or cap over the drawbar bolt which resist the force of the screw coming up. Rather simple really.
Henning
Re: home made mill
« Reply #92 on: February 20, 2017, 06:28:49 PM »
hi its a live its a live made my take on the ejector nut 17mm c/f stanles steel drilled out to 15.3mm taped 16x1 mm by 30mm deep drilled a 7.3 hole in the top for the alan key to fit threw clocked the head in had a bit play with a block of aluminium then put the flats on the two new back lash screws then made up the two locking screws  right sum pics    ps   any on no where I can get sum of that lovear rubber to make bed covers with
Re: home made mill
« Reply #93 on: February 21, 2017, 12:33:30 AM »
Well done Bob your a man of many talents! :thumbup:
Re: home made mill
« Reply #94 on: February 22, 2017, 04:46:35 PM »
Very nice Bob
Wont be long until we get some video of the mill working
Re: home made mill
« Reply #95 on: February 22, 2017, 04:49:44 PM »
Nicely done Bob...   :thumbup:
Arceurotrade sell rubber way protectors....
Re: home made mill
« Reply #96 on: February 22, 2017, 07:41:54 PM »
hi john rudd glad you like the work so far yep bin informed by mick will av a look on line
Re: home made mill
« Reply #97 on: February 27, 2017, 05:32:21 PM »
hi all bin bizz with the mill this weekend the two brackets on the top table had to much play in them sos no pic of this bit but on the first bracket on the back side the hole was 11.5mm and at the front 10.5mm so had a rut and fawned sum 12.7mm O.D  with a internal of 9.5 oil light bushes  just the job as the shaft is 10mm so reemd out  the bracket with a 12.7 mm  reamer then with sum Bering fit put them in but left a oil gap between them then once the stuff had gone off reemd out to 10mm then lost the key one the end of the shaft mad a new one then fawned the old one  :doh: any way all fitted up nice next make two oil ports only got on dun will do the other one tomorrow just need to fit the spring and drill the bracket  right pics
Re: home made mill
« Reply #98 on: February 28, 2017, 02:40:16 AM »
Re: home made mill
« Reply #99 on: March 03, 2017, 06:16:03 PM »
rather make me own
