Author Topic: Another use for that forgotten vertical slide.  (Read 11727 times)
« on: July 07, 2016, 03:21:23 PM »
Anyone tried this technique ?
Could be handy for hogging out spokes etc.
Note, the music is rather annoying.
Re: Another use for that forgotten vertical slide.
« Reply #1 on: July 07, 2016, 03:45:23 PM »
Seems a long winded way of making it , simple turning job as I see it .
« Reply #2 on: July 07, 2016, 04:35:12 PM »
Those boys are in serious need of a simple CNC  mill  :lol:
  • Country: ie
« Reply #3 on: July 07, 2016, 04:39:10 PM »
I assume the "college" pays for the raw materials!
« Reply #4 on: July 07, 2016, 05:19:29 PM »
I second that  :thumbup:
« Reply #5 on: July 07, 2016, 08:26:08 PM »
Who needs CNC when you've got 1YSC (1st Year Student Controlled) :) Cheaper, and easier to replace if things go wrong  :lol:
What I want to know is.... what IS it they were making? And what's it for?
« Reply #6 on: July 08, 2016, 02:17:10 AM »
It's a support for a clock ballence wheel to let the wheel outside of the plates , to allow it to be seen .
« Reply #7 on: July 08, 2016, 03:54:22 AM »
I thought they just made the swarf for the heat bath at the end.
« Reply #8 on: July 08, 2016, 05:30:54 AM »
Whilst I agree that the job could have been done just as easily on a milling machine, it does show how you can add another axis to your lathe. And maybe the whole point was to illustrate a different technique.
The clock making fraternity do like their 'glued on' work holding.
Does anyone know if the method used was once in common use amongst clock makers ?
« Reply #9 on: July 08, 2016, 06:28:26 AM »
Yes, but they used to use wax chucks in place of superglue.  My mentor taught me how to use a wax chuck and I keep a couple of sticks of sealing wax handy in the event.
« Reply #10 on: July 08, 2016, 09:31:04 AM »
I experimented a few years ago using special thin wax film to bond panels that I was CNC machining. Never did get a satisfactory result, it often letting go even with very light cuts, and of course any heat and it melted  :bugeye:
Then I went on to double sided tape, which is better but suffers two drawbacks. Firstly removal - hard to pull a thin sheet off without bending it and also hard to remove the goo from the part and platen. Secondly when cutting all the way through bits of the goo would gum up the cutter retaining chips.
I haven't yet tried super glue but I remember Steve (VTSteam) gluing his tractor cylinder head to his mill table for machining quite satisfactorily.
Offline ieezitin
« Reply #11 on: July 08, 2016, 06:16:34 PM »
Nice concept.... with slight redundancies...
Damm the kids today even have to sit down while machining.... I really am loosing touch.
Anthony.
« Reply #12 on: July 09, 2016, 06:25:01 AM »
..Damm the kids today even have to sit down while machining.... I really am loosing touch...
Yes.  There is nothing more character forming than spending eight hours a day standing operating a lathe that is a few inch below the correct height.
Offline Pete49
« Reply #13 on: July 09, 2016, 11:37:36 PM »
My lathe was setup so I can sit down while working due to a bad back but I still stand to get measurements or when I need to make critical adjustments
Offline Bryan Smith
« Reply #14 on: July 25, 2016, 02:34:54 PM »
We always used melted orange flake shellac to hold watch and clock parts on wax chucks, then dissolved the residue in denatured alcohol.  Super glue is the new way of doing it.
Offline howsitwork?
« Reply #15 on: July 25, 2016, 02:55:52 PM »
Andrew et al
Superglue works well provided surface is clean and of reasonable area
To get it off afterwards sit it in a bath of nail varnish remover overnight in sealed container ( or just enjoy the fumes whilst you finish your nails.... :coffee:
Offline nrml
« Reply #16 on: July 25, 2016, 02:59:41 PM »
This is a very neat way of using superglue for workholding.
&index=1
The video is a little bit long winded (no offence intended towards the guy who made it) but it is well worth a watch just to see how effective the technique is.
« Reply #17 on: July 25, 2016, 03:20:18 PM »
Interesting  :thumbup:
Is there anything special about the green masking tape he was using - never seen that before  :scratch:
(I was rather concerned about the amount of sawdust in his Z-Axis screw)
