Author Topic: DDCSV1.1 4 Axis controller  (Read 1643791 times)
Offline Merlin201314
  • London
« Reply #225 on: November 23, 2016, 02:39:35 AM »
If you have a close look at the video 📹,  you can clearly see at some point that at the right bottom ↘ of the display under the firmware version is not saying D DREAM  but RATTMOTOR,  so clearly they changed the firmware,  WE NEED TO FIND THE BLOODY WAY TO DO IT!!!
Sent by my tapatalk
Offline Benedikt
« Reply #226 on: November 23, 2016, 03:22:32 AM »
Sent by my tapatalk
The only impressive thing would be if they had changed the bootlogo. Changing the text in the bottom right is easy. I did it on the custom firmware i made.
  • London
« Reply #227 on: November 23, 2016, 03:31:00 AM »
Heiii, welcome back!!
they did indeed!!
Look
This is another company that use the same controller, and is changed
  • London
« Reply #228 on: November 23, 2016, 03:59:29 AM »
So, Benedikt, you will need IDA for doing the job? as i understand?
Offline Benedikt
« Reply #229 on: November 23, 2016, 04:25:16 AM »
Yes, indeed :(
However if somebody could do it for me or point out a somewhat similarly featured armv5 decompiler then it could still work.
  • London
« Reply #230 on: November 23, 2016, 05:47:43 AM »
I just received a message from a friend, it say that with the 4 axis software installed, even if the DRO is not showed on the display, the axis is still working :jaw:
Let's give it a try!!!! :drool:
« Last Edit: November 24, 2016, 04:34:12 AM by Merlin201314 »
« Reply #231 on: November 23, 2016, 07:55:57 AM »
That Ratnmachine one in the video is the one I have.
  • London
« Reply #232 on: November 24, 2016, 03:43:18 AM »
Ok guys, i'm looking to build some macros for the tool change, hoping that now Benedikt can finally open the core of the program.
The other shield is now this: normally in a serious controller you have a PLC which can be programmed exactly to do the job, just by calling a function,  and in this case is not present i guess, unless Benedikt find out that we have one embedded and is just there sleeping, which i doubt.
Or we will need a portion of the memory to store routines that can be called by the command(M6 in this case), and dedicated screen page to setup all the steps to store the tools position on the "map"
Never the less, we have the TOOL OFFSET for 13 tools in the setting function, so why is there if we cannot use it'?
There's something souspicious here :coffee:
I strongly invite all of us to give a personal opinion, no matter if good or not, anything help at this stage if we want to build up something that really work.
Regards
Emanuel
Offline Benedikt
« Reply #233 on: November 24, 2016, 05:15:35 AM »
 :mmr:
I have been sent IDA and someone is in contact with somebody else having access to NDA info on the bootloader.
What a great community!
  • London
« Reply #234 on: November 24, 2016, 05:18:23 AM »
:mmr:
NICE!!!!!
Hopefully we will do it!!
Was IDA the version you need?
Offline Benedikt
« Reply #235 on: November 24, 2016, 10:34:17 AM »
So, while this is not related to the controller modding, I have just received my lasered plate in the mail.
I already temporarily installed the components. It does not look bad but the fit is really tight at some spots even though I have planned plenty of tolerance in.
  • London
« Reply #236 on: November 24, 2016, 10:38:23 AM »
Nice job,
Shame for the 2 holes near the controller, i'm assuming they are to retain it in place,
You should receive 2 piece of plastic with your controller, and 2 bolts and nuts
I'll post you the pictures in a few minutes if you don't mind, im just in the process to finish mine under the router
« Reply #237 on: November 24, 2016, 11:07:19 AM »
Blimey that's the size of a Rugby pitch - spreads off my monitor and onto the workshop walls and ceiling  :bugeye:
  • London
« Reply #238 on: November 24, 2016, 11:13:37 AM »
Sorry, i always have problem uploading pictures, don't know why
Any help is apreciated :bow:
« Reply #239 on: November 24, 2016, 11:19:00 AM »
I expect that you are on a Unix machine, but in Windows, resizing is dead easy. right click the file in Explorer, select 'open with' and 'paint' then select 'resize, then 'pixels' then 640 x 480 - save file with a new name, then everyone can enjoy your pictures without knocking the boy off his bicycle on the other side of the road  :ddb:
  • London
« Reply #240 on: November 24, 2016, 12:01:42 PM »
 :lol: :lol: :lol: :lol:
  • London
« Reply #241 on: November 24, 2016, 12:04:53 PM »
Here you go.......(Maybe)
« Reply #242 on: November 24, 2016, 12:05:45 PM »
Nice picture size  :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
  • London
« Reply #243 on: November 24, 2016, 12:10:20 PM »
Here is my Panel, need just paint the carved letters white inside,  clean up and finish with a hand of transparent on top.
  • London
« Reply #244 on: November 24, 2016, 12:22:35 PM »
And here is Mounted on the new controller box front Bezel
  • London
« Reply #245 on: November 24, 2016, 01:28:22 PM »
Is not that bad......
  • London
« Reply #246 on: November 25, 2016, 09:41:09 AM »
The back panel,
here is the link on eBay for the pc case: http://www.ebay.co.uk/itm/112007556057
Is small, but do the job.
Offline Benedikt
« Reply #247 on: November 25, 2016, 09:43:08 AM »
The back Panel
Looks great! Good idea to use a PC case.
I went for the angled panel as you know.
By the way I managed to secure the controller by messing with the plastic pieces a little, so this problem is now thankfully solved.
  • London
« Reply #248 on: November 25, 2016, 09:49:03 AM »
The back Panel
Ohh really god, is a pain when the things doesen't fit as aspected!! :thumbup: :thumbup:
I was looking for the angled case, but i couldn't find anything, so i just got this one...
will post the pictures of finished case soon, including the internal layout.
  • London
« Reply #249 on: November 25, 2016, 02:12:45 PM »
Question:
Did anyone found out how to work with the "tool offset" in the parameter list?
I am trying to understad how i can use them, but no results nor response from the controller
Very frustrating!!!! :bang:
