Author Topic: Radiator build  (Read 2730 times)
Offline Doc
    • My Youtube Channel
Radiator build
« on: July 05, 2017, 09:08:21 AM »
Here is my radiator build for my Little Demon V8. This is the first one I have done I did attempt and failed miserably to build the one in the plans so I made up my own. Here is a short video showing it so far it has to be cleaned up and finished yet.
Offline Doc
Re: Radiator build
« Reply #1 on: July 07, 2017, 03:17:41 PM »
Well I cut one side flashing and am going to try and make the radius on the tanks smaller to blend more withe the side. Anyway here is a short video taking a peak at what its looking like.
Offline Doc
Re: Radiator build
« Reply #2 on: July 15, 2017, 10:14:35 AM »
Latest update plus started 2nd one.
Offline Doc
Re: Radiator build
« Reply #3 on: July 22, 2017, 08:06:53 PM »
Another radiator update.
Offline Doc
Re: Radiator build
« Reply #4 on: August 13, 2017, 09:32:31 PM »
Was going t post an update video with the soldering of the 2nd radiator but unfortunately my video card went bad. I videoed the soldering and when I went to pull the vid off camera I got a file corrupt I tried taking the card and putting it in a card reader and got the same. Dam it anyway. So I need t get a new card.
I do have question has anyone tried these tach meters I am thinking of putting one on but kind of curious as how went they work (or don't)
Here is a link to what I'm talking about.
Blue LED Tachometer RPM Speed Meter
Re: Radiator build
« Reply #5 on: August 14, 2017, 03:45:32 AM »
I have one on my lathe as its a varible speed  , works well up 2000 rpm , been working for two years .
Offline Doc
Re: Radiator build
« Reply #6 on: October 05, 2017, 09:05:57 AM »
The RPM gauge seemed to respond slow so I didn't use it. I did finish up the rad's and mounting box and gave them a little run.
[ Invalid YouTube link ]
eskoilola
Re: Radiator build
« Reply #7 on: October 05, 2017, 09:35:52 AM »
It is a hall sensor so it reacts on a magnetic field. Obviously the pill supplied is not to be swallowed but glued someplace where the sensor can sense it.
So, I assume, the pill is glued on a rotating surface and the sensor attached nearby.
Basically hall sensors can detect frequencies high enough for this kind of use. The sure can do 1000Hz -> 60000 Rpm.
The electronic involved is very simple frequency counter.
These work. They will flicker on low rpm:s but stabilize as the rpms get higher.
