Author Topic: Sewing Machine Modifications  (Read 70587 times)
Offline S. Heslop
Re: Sewing Machine Modifications
« Reply #25 on: April 08, 2019, 05:08:53 PM »
Also am I right to assume that any bipolar stepper motor driver with the right current & voltage rating would run any bipolar stepper motor? I've got a bunch of drivers hanging about. Lyn sent me a few and i've got some A4988s from the 3d printer adventure.
This spreadsheet may be of some use.
Thanks!
Here's a blurry photo.
It's been slow going so far, getting distracted with other duties. Need to put some holes into the arm then weld that into the column. Still thinking about if it'd be better to weld the column to the base or to try fix it with bolts. Jumped the gun a bit on welding the column pieces, but I wanted to weld something...
Offline S. Heslop
« Reply #26 on: April 19, 2019, 05:22:43 PM »
Still puttering away at this as time permits. Decided to ditch the electronic zig-zag idea since i'm not sure if it'd work. Spent today measuring up all the important zig-zag stuff from the donor machine.
Plan is to just turn some pillars to get the heights correct and mount it all. Shame all the screws in it are imperial. I've got alot of imperial taps I never use because... i've never had to. But i'll dig through and see if I have what I need.
Speaking of imperial, the worm screw cut into the shaft measured to somewhere around 4.8mm thread pitch. I cut a 5mm thread into this part to see if my lathe could handle it. Just barely... had to clean up the chatter with a file. It of course doesn't mesh well with the existing gear so i'm going to have a go at 3d printing a replacement.
Was hoping to get more done today but I spent alot of it taking the lathe apart to try find a fault that didn't exist. It needed a good clean anyways though.
« Reply #27 on: April 19, 2019, 05:34:06 PM »
Your worm pitch is (obviously!) set by the pitch of the gear that it meshes with so will almost certainly not work out to round numbers - it is dependent on the gear 'family' be it Module (metric) or DP (Imperial)
Offline S. Heslop
« Reply #28 on: April 20, 2019, 04:47:14 AM »
I thought I could just make the gear to match! I guess i've made another sculpture.
Seems my lathe didn't come with a 57 tooth change gear, which I've read is supposed to be standard. I've ordered that as well as a 45 tooth gear - which should let me cut a 4.75mm thread pitch and re-use this existing gear. It also turns out I can pass the 13mm bar through the headstock. I thought the hole was smaller than that. So I could cut the thread directly into the shaft like on the original machine too.
Offline jatt
  • chookshed engineer
« Reply #29 on: August 05, 2019, 08:12:16 AM »
Only just noticed this.
Got 8 industrial sewers (at last count).  All walking foot.  Needle feed machines (bobbin accessable from top) don't require 1 to turn their wrist inside out to get to it.  Got both kinds.  Advantage of course with bobbin underneath is if you are working in the middle of something big, can load a fresh bobbin up and keep sewing.  No need to remove work.
Never used a zig zag machine, just plain lockstitch sewer, so cant offer anything there.
Once one has a long arm, wonder how you did without it. Picked up mine (twin needle) on the secondhand market.  But looking at the machines you are playing with, prob a bit on the heavy side.  Head alone is a bout 100Kg according to the specs.
As for servo motors, personally wouldn't go near one.  All my stuff is the clutch motor type.  Good thing is parts avail for these kinds of machines is still quite good and the gears are metal.
Contemplated doing what you are doing to one of my smaller machines, but it never got past a thought.
Good luck with it
From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
Forget about the price of gold and oil, its the price of beer that matters.
Offline S. Heslop
« Reply #30 on: August 08, 2019, 01:01:07 PM »
Good luck with it
Yeah I had some problems trying. I think it'd be entirely possible with a milling machine but all I managed to do was wreck a couple of machines.
I guess for an update, I spent a while trying to track down an industrial machine at a reasonable price. The best i've seen was a Singer 457 at around £200. I also went to a couple places dealing in 2nd hand ones and it sounds like I missed the boat on finding a machine for cheap, since there were alot more floating about 5 or so years ago when factories were still closing.
I've moved on to knitting machines since those are available for reasonable prices. Messing around with a Singer Memo 2 at the moment but i'm holding off posting about it till there's something worth showing, just in case I hit another wall like with sewing machines.
