Author Topic: Jeweler's Resource  (Read 35408 times)
Offline PTsideshow
Jeweler's Resource
« on: May 11, 2008, 12:57:48 PM »
Jeweler's Resource
A reference of Gems, Metals, Formulas and terminology for Jewelers
Revised Edition
Bruce G. Knuth
Jewelers Press
Copyright©2000
ISBN# 0-9643550-3-5 spiral bound lay flat when open trade paperback 8 1/2"X 11"
Small press publisher
Jewelers Press
box 103
Eastlake Colorado 80614-0103
Contents:
   1. Gems and Gemology
   2. Metals and solders
   3. Chemistry and Formulas
   4. Measurement and Calculation
   5. Glossary
   6. Index
Although it is titled a jewelers book, it is one that a metal smith could find helpful. The chapters are further sub divide into sections on a subject.
    * Mohs hardness
    * Metaphysical properties
    * Diamond legal standards
    * Coin sizes
    * Birth stones
In the 1st chapter.
    * Copper Based Alloys
    * Brass and Bronze Alloys
    * Silver Solders
    * Fluxes
    * Anti Fluxes,Soft Solders, Pickle solutions and Firescale,Bright dip
In the metals chapter along with the other metals noble and non noble jewelry metals, pewter, Japanese alloys.
Also on each metal it gives the legal standards if needed along with other information and then a chart with alloy and common trade name terms for the metals. Karat and alloying info.
The chapter on measurement and calculations:
    * Ring Sizes and Ring Blank Lengths
    * saw blade sizes
    * Burs Shape and Sizes
    * Tempering Steel
Along with more of the standard useful formulas used in a metal working shop.
The Chemistry chapter:
    * Patina's
    * Heat Coloring
    * Etches and Mordants
    * Along with Gold Gilding, Niello, and Resists
If you find your self always looking for an obscure bit of info,than this maybe of help at your bench.
It is scattered in libraries around the world, so you can use
World Cat and see if it is in one near you
Mostly available at jewelry supply houses, from the publisher.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
