Author Topic: House floor plan softwear  (Read 8838 times)
Offline HS93
« on: January 11, 2012, 08:18:42 PM »
Hi does anybody use a cheap softwear package that I can use to draw a house floor plan with I need to alter the house so I can get around in a chair and need to move some walls I want to draw it out so I can see what the options will be, what I am after is something simple and cheap that you can print out if posable when finnished, I dont want to have to get my old drawring board out
so any recomendations would be good I have done the google search thing and got few up with the rigmorole of the try it for 30 days ones I tried unless there is a good one
Peter
Offline cuog
Re: House floor plan softwear
« Reply #1 on: January 11, 2012, 10:43:51 PM »
Pretty much any 2d cad should let you do the basics, for 2d cad I've been using QCAD on linux(windows version is a bit limited) and it works well enough for the basics
« Reply #2 on: January 11, 2012, 11:28:38 PM »
Hey Peter...
Does this help?
Link
Offline HS93
« Reply #3 on: January 12, 2012, 04:40:04 AM »
ill give it a try thanks
Peter
